Effective vs Equivalent Gear Ratios
Old Mar 13, 2005 | 09:45 AM
Cebby's Avatar
I saw a real simple explanation of how to calculate your gearing on Xtreme 4x4 today. Both how to figure out what your big tires did to your gearing and how to figure out what gearing will take you back to stock.
I'll use my rig as an example. I went from 31" to 33" tires - rig came with 4.88 gears.
Effective Gearing - (what has going to big tires done to the gearing)
[Old size] divided by [New size] multiplied by [current gear ratio] = [New effective ratio]
Example: [31] divided by [33] x [4.88] = [4.58]
Equivalent Gearing - (what gears do I need to swap in to get back to "stock" gearing)
[New size] divided by [Old size] multiplied by [current gear ratio] = [New equivalent ratio]
Example: [33] divided by [31] x [4.88] = [5.19]
Old Mar 13, 2005 | 10:13 AM
terryjmatthew's Avatar
I also saw that show yesterday.
Thats the only piece of good info that I have taken away from watching it...
Old Mar 13, 2005 | 10:33 AM
Cebby's Avatar
Yeah, no kidding....
Old Mar 13, 2005 | 10:48 AM
86toyota's Avatar
So how many inches is a 235x75x15 ?
Old Mar 13, 2005 | 11:11 AM
Cebby's Avatar
Here's the formula for converting metric tires to inches:
Using your numbers: 235/75R15 (235mm = width, 75 = aspect ratio - percentage of width to sidewall height, 15 = rim diameter in inches)
[metric width] divided by 25.4 gives you width in inches. (25.4mm in an inch)
Take the width in inches and multiply it by aspect ratio (ie 75 = .75, 70 = .7, etc.) which gives you (1) sidewall height.
To get diameter, take sidewall height multiply by 2 and add the rim diameter.
Example:
[235] divided by 25.4 = [9.252"] wide
[9.252"] multiplied by .75 = [6.939"] sidewall
[6.939" x 2] = [13.878"] total sidewalls
[13.878"] sidewalls + [15"] rim diameter = [28.878"] overall diameter.
Keep in mind this is how you calculate the diameter. The actual size may deviate slightly from the given dimensions.
Old Mar 13, 2005 | 11:16 AM
Cebby's Avatar
So, Gregg - if you had 4.10's stock with 28.878 tires and moved to 33's, here's the effective and equivalent gearing:
Effective: 28.878/33 x 4.10 = 3.59
Equivalent: 33/28.878 x 4.10 = 4.68
Old Mar 13, 2005 | 11:27 AM
86toyota's Avatar
Yes, that's my current setup. I had put in 4.88's, they were set up wrong and only lasted a month in the rear. So I bought a third setup with 5.29's from NWOR(never again) and they lasted 5 years before they broke. So I'm back to stock now. I preferred the 5.29's over the 4.88's . When I get some money again I'm going to regear again. Thanks for the math.
Your truck came stock with 4.88's?
Old Mar 13, 2005 | 11:51 AM
Cebby's Avatar
Yep, 3.0 V6, auto tranny with factory alloys and 31" tires came with 4.88's stock. You can probably find some factory 3rds that would bolt in. Generally 90-95 4Runners had this setup.
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
