install help
Old Feb 22, 2005 | 03:21 PM
jhcmhower's Avatar
install help
who knows anything about installing an ARB winch mount bumper+winch the instructions they sent s*ck?
Old Feb 23, 2005 | 06:33 AM
MudMonkey's Avatar
This should be in the offroad tech section.
Old Mar 2, 2005 | 09:06 AM
Shane's Avatar
Might help if you give more info, ARB makes bumpers for dozens of vehicles and they're all different. Or you could call them...
ARB 4x4 Accessories
20 South Spokane Street
Seattle WA 98134
Tel: (206) 264 1669
Fax: (206) 264 1670
Old Mar 2, 2005 | 01:05 PM
4Crawler's Avatar
What difficulty are you having? From the ones I have seen, you remove the old bumper and put on the new bumper. I think the winch needs to go in with the bumper off. 4 bolts in the base of the winch, hook up the fairlead and wiring and you are set. I wrote up my (not ARB) bumper/winch install (I had no instructions and even had to fab my own bumper brackets):
http://www.4crawler.com/4x4/4R_bumpers.shtml#How-To
Old Mar 11, 2005 | 07:48 AM
PAhydrohead's Avatar
Anybody know what the gold colored threaded inserts are for in the attached photo? Light mounting bracket? ARB instructions surely don't help
Old Mar 11, 2005 | 08:10 AM
seaflea's Avatar
I used the holes for mounting lights. I just assumed thats what they were for.
Old Mar 11, 2005 | 09:32 AM
If I understand you correctly, you passed the threaded stud on the bottom of your light through the HOLE and then threaded a nut and a big fender washer on the underside of the bumper, right?
Or did you thread the light directly into one of the two gold inserts which would mean you didn't have to use a nut or washer b/c the gold insert is female threaded already.
Old Mar 11, 2005 | 09:48 AM
seaflea's Avatar
Actually I too some plate (1"x3") and mounted my lights to that. Then I drilled holes in the location of the gold inserts. It was necessary for me to do this because my winch is less than a quarter of an inch from the top. Here is a pic.
This is before I mounted the lights. Its not very good, but you can see that it is a tight fit.
Old Mar 11, 2005 | 12:42 PM
Shane's Avatar
Your parts kit should have come with a couple diamond shaped black steel plates that bolt to those, and have a hole in the center for the light to bolt to.
Old Mar 14, 2005 | 07:30 AM
Thanks shane,
I found the steel plates you mentioned. Why didn't ARB just drill a smaller hole in the bumper?? Seems like a waste to bolt a plate on just to provide a smaller mounting hole . Looks like I'm going to have to go without the plate b/c my PIAA 80 pros hit the top bar of the bumper with it in place.
Old Mar 14, 2005 | 03:21 PM
Shane's Avatar
As was previously mentioned, bolt clearance for the winch. Makes it much easier to install lights with a winch already installed as well. The hole underneath is larger in order to clear a nut.
Old Mar 15, 2005 | 05:00 AM
A-ha. I missed that in your previous post. :pat: Now that I have test fit the winch in the bumper I see what you mean.
nvdesertrunner
May 11, 2020 08:18 PM
wwjr
Sep 7, 2015 09:27 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
Esibnitsud
Jul 30, 2015 08:19 PM
