budbuilt....done
Old Feb 27, 2005 | 11:18 PM
anthony1's Avatar
budbuilt....done
I finally got around to installing the dual case version of Budbuilt cross member.
I didn't use the other peice that came with it yet. I don't actually have dual case yet It does cover the whole thing pretty well.
Old Feb 28, 2005 | 04:08 AM
dogdenii's Avatar
I highly suggest that you get some washers between those bolt heads and the x-member. BIG ones that disperse the weight on the bolt head.
Old Feb 28, 2005 | 04:57 AM
Ilovemountains's Avatar
Exclamation I agree.
I would upgrade to grade 8 bolts and put some large washers on there also at the very least add some large washers, the first time that skid hangs up on a rock its going to pull right over the bolt heads!
Old Feb 28, 2005 | 06:09 AM
mt_goat's Avatar
If those are the stock threaded holes they would be metric and "grade 8" is a standard thread classification. There is a grade 8 equivalent in metric (class 12.9) but get out your $$$$$ for those puppies. If it were me, I'd probably stay with the lower grade bolts for that location unless I was going to be racing over the rocks. I would get some grade 8 washers though, Lowes sells them and you could find a size close enough to the metric size bolts to work.
Old Feb 28, 2005 | 08:16 AM
anthony1's Avatar
I was thinking of getting better bolts and washers. I also want to make something to prevent rocks from shearing the bolts from 1/4" C channel.
something that looks like this... /_______\
Old Feb 28, 2005 | 08:21 AM
96LtdYota's Avatar
just cut a 1/4 inch sliver off of a 1 1/2 to 2 inch pipe and weld it on around the bolt area...
