View Full Version : Offroad Tech
Pages :
10
11
12]
13
14
15
16
17
18
- Removed my rear bumper...
- painting the ARB?
- ? about Marlin Sliders
- Tacoma owners! 33's w/ 5 inches, 35's w/ 8 inches!
- 2ng gen pickup IFS questions.
- 3rd Gen: Stock Hitch + Shackle Hangers?
- Installing Sonoran Steel Shackle Hangers
- will my stock lugs work w/ my new rock crawlers?
- Some E-locker questions..
- Thought on new warn rear bumper?
- Gen 4 2005 4Runner OME susp lift info?
- i want to run 58s on my runner
- Surf Trip to Central America, what to bring, how to seek sponsorship?
- I want 35's on a Tacoma
- Detroit EZ locker questions
- Tacoma/ARB/stock skid foolishness (on my part)
- 2nd gen IFS *measurement request*
- block lift on front axle
- P/U in-bed spare tire carrier in a 1st gen 4Runner?
- Lifting, Bigger Tires, Locker? - 1986 2WD Pickup
- Finally Complete - OME lift, 285s, TJM
- CV angles too much?
- e-locker deal or no?
- body lift probs...
- Newbie
- What to Do for the future. Tires/Gears/Lockers
- OME860 & BJ ** OR ** 2" BL???
- Lifted my 2000 Runner
- Anyone know how much a filled gas can weighs?
- Body Lift
- ARB or Tjm Bull Bar
- gears or locker
- Just installed lift (pics)
- Want bigger tires
- Downey Bilstein Coilover lift
- Lars Disco's parts
- 3rd Gen Drive Train Lift?
- 1985 4runner build up
- Drivetrain lift via crossmember?
- 2nd gen rear leaf spring conversion?
- adjusting torsion bars on 2nd gen
- 96 4runner on 35's....need some help
- parts!!!!$$$
- Body or Suspension?
- Truetrac Limited Slip - opinions wanted
- newbie lift ?s 96 tacoma
- Need more flex!
- backspacing for 16x8 rims with 285's
- Question on rear shock removal for 3rd gen
- Blocks in the rear
- help question
- All Pro Tcase Brake, good idea?
- mudterrain tires
- bj spacers.
- 2WD lift kits???
- 3rd generation pics of lifts/tires
- What's this funky bump on the rear diff?
- Balljoint spacers...
- Downey Double shock loops
- Spare tire mounted gas can...?
- Removing Air Conditioning or converting to air compressor???
- suspension newbie
- What back spacing to use?
- Rockstomper flip and shocks
- Undercarriage Camera!
- Spend my money!!!
- Wiring 2nd set of lights
- Anyone from B.C./Canada do a TRD/OME suspension lift?
- Leaking Front Pinion Seal
- Georgian in need a little help installng lift kit
- 4th Generation OME Update
- Shock length/Alignment
- Lift comming
- Axle Wrap?
- The Dilema of Balancing Big Tires
- Stacking Top Out Spacers..
- Trade full OME lift for factory suspension with low miles
- 2000 Tundra TRD 60k maintenance
- Positive locking Diff locks
- OME lift installed...no bumper.
- Towing 86 runner with 90+ runner??
- weight on fj80 coils
- Most Important upgrade
- just how much stonger is a V6 vs 4c 3rd
- Introducing the HELLICA!!!!!!!!!!
- New Meats on the way!! Thanks to SeaFlea
- Rear suspension
- Inverted front leafs (85 4r)
- Shackle Lifts
- ome shocks and stock springs ?
- Using coilovers with a ARB bumper?
- Calling all people with lockers...
- 2nd gen OME's
- Chads SAS and Exo Cage 97 4runner
- Front Locker Install!
- What's best way to regain 1/2 to 3/4" lift in rear due to heavy bumper?
- front suspension lift problem...help
- Some Updates
- Front and rear bumper options for 82 4x4
- Spare Tire On A Carrier Or Under Veh
- BJ spacers and CV blowout...
- Grill Guard- how much to pay
- installed my aussie and 4.88's. but they whine
- 4.88 or 5.29
- e-locker factory safety disable
- My new little 12V compressor is mounted.
- Superlift front and OME shocks...
- Rear end shimmy - 3rd Gen 4Runner
- panhard bar HELP!
- Installation of Rock Sliders
- 2nd gen 4Runner tailgate adjustment?
- To snorkel or not to snorkel??
- Question about Lee's setup. (PP 1" Lift Springs)
- 2" lift options
- FJ80 Rear Coils on a 3rd gen?
- Manual hub swap on 3rd gen 4runner
- gen 2 rear sag
- Which lift is cheaper?
- Who wants an MV-50?
- What is a 3 link and do iI need one?
- Warn M8000 winch install question
- 3.5' fabtech performance lift
- Converting 4x2 to 4x4
- Long Travel 1st Gen.
- Time for new shocks
- CHEVY Rear Leafs on SA yota
- Tacoma t-case/auto trans breathers
- 3rd member ???s
- Water proofing a 1998 3.4 L Taco 4x4, how?
- my xd-20830 has arrived.
- Last Strap Question Before Purchase!
- post BJ spacers...
- 35s?
- Is it ok for springs to go into negative arch?
- Looking for suspension lift suggestions.
- Looking for Alignment shop around San Jose
- another BJ spacer/ LC coils Thread
- HELP with LIFT?!!
- 4th Gen + Daystar lift ... Camber Adjustment?!?
- Looking to go to E-locker
- MasterFlow & SuperFlow air compressor MF-1050 & MV-50
- New coils, new problems
- Coilover SAS for 85-95
- sliders are on!
- Buying a WINCH
- 1995 4 runner lift
- ARB Bumper and Warn winch
- A340H Automatic Tranmission and crawler gears...Now it CAN be done!
- max tire size for IFS?
- Lift question for 00 4runner
- Won an air pump, advice for the install?
- tried on a 38.5x14.50 Interco TSL/SX tire
- How do I compress at full the rear suspension?
- 87 Turbo Tranny/Transfer case.
- 99' lift
- BudBuilt skids for tacos now available
- OME vs. Rancho stiffness
- 2nd gen 1.5 lift -what shocks to run?
- Torison bars
- Why are these winches so cheap? Am I missing something?
- tires 265 or 285
- demello sliders for 4th gen 4runner
- what to do for e-locker?
- Off Road Wheel Sponsor for DGC
- where to buy a good cheap flexy lift?
- broke a birf found a weird part on the diff side of the knuckle
- what are all my options for bumpers?
- Probably NOT...the last 4th gen 4r lift question..(specifically about the OME kit)
- Expedition Camper - sleeping solution
- Trailmaster lift installed! Pics inside!
- 33's or 32's?? sorry I have to ask
- QuickAir II & ARB locker (OBA system)
- Somewhat out there idea for a new type of SAS?
- Need help finding Bilsteins 5100's for my '82 Pickup! PLEASE HELP
- Fastest,easiest way to lift this thing
- Is disconnecting an IFS front swabar stupid ???
- Downey Leaf Springs
- Where to get best pricing for 3rd gen lift?
- Tire Size Info FYI
- Quick Disconnects for 96 Runner
- Rear shackle is seized!
- 8" IFS in a 1st gen?
- Gear Drive Tcase Schematic
- warn hitch receiver
- Bentup or 4Crawler rock sliders?
- Driving with a Locker ????s
- Manual Hub Q's Who's best??
- Locker on stock 4.88 gears
- front tow hook
- Lockrite & Gears Installed
- Stock Height Shackle?
- Advice Needed: Would like to add top out spacer and/or coil spring spacer to OME
- Undercarraige Rock Lights shopping
- Tow Strap
- Is removing the overload safe?
- Hawse, or Roller Fairlead with Plasma Rope?
- Warn Winch Wiring Nightmare
- How do I make Rock Sliders?
- need some better leaf springs
- Got my ARB bullbar on
- Dual mini Yellow tops or Single large yellow top?? that is the question
- Backspacing on 02 Taco?
- Check out my new sasd 86 4runner
- Shackle Hangers, for cheap?
- Running boards off
- No more doors **Img Heavy**
- steel stake pockets
- 930 and 300m cvs
- WANTED: your 2 cents.
- 2nd gen lift concerns
- 88 4Runner Internal Cage - pics
- truck is of age!
- Lunchbox locker driving tips?
- Tundra Setup is now finished
- Need Info On Lift Kits For '97 4runner Sr5
- Small front lift
- 3rd Gen Pan Bar Install after OME Lift question
- Warn Premium locking hubs
- Tjm-13 Bumper On My 2nd Gen With Pics!
- Front Dual Shocks
- 94 4Runner- What size lift should I specify when ordering my shocks?
- Front struts new but terrible
- Toy e-locker idea
- 3'' Lift kit? 02 Taco Prerunner
- tundra coil overs
- Tundra coil question...
- What to do about the rust attacking my 89
- Removal of Top Out Spacer
- Fitting 37's
- BigRocks Offroad sliders?
- shock dilemma
- Needing Help Deciding and Finding.
- Wiring IPF lights
- Body lift install question
- Vacuum Lines
- air locker questions
- Finally got the 35s mounted
- cornfed suspension
- 2nd Gen RS9000 shocks for 1.6'' lift?
- 94 4runner sas dana 60 built v8 39.5 iroks
- How does this sound for lift and tires?
- 315/75/16 3rd gen ?
- OEM Carrier Assembly Locker or lockright?
- anyone own a 4 inch pro comp lift?
- Lift with New Springs and Shocks
- Lift Kit - Install Cost
- BJ Spacers and Coils?
- Locker from a '98 to my '99
- Hummer Style Tube Skid Plates?
- certain lockers for certain gears?
