block lift on front axle
Old Sep 6, 2005 | 03:40 PM
toy94ota's Avatar
Is it possible (safe) to put blocks in front just like u can in the rear instead of buying add a leafs or new spring packs? Just wondering I have an 85 ext. cab 4x4.
thanks, Toy94ota
Old Sep 6, 2005 | 03:43 PM
jimbo74's Avatar
blocks anytime is unsafe, they are even worse on the steering axle... i would never put blocks on a front axle..... save up a few bucks and get some cheap front springs
Old Sep 6, 2005 | 03:46 PM
Intrepid's Avatar
This is a big resounding NO! Blocks on the front are incredibly dangerous. Don't mess around with that.
Old Sep 6, 2005 | 03:51 PM
humboldt's Avatar
Don't do it. You'll end up on the scary steering page:
http://128.83.80.200/taco/scarysteeringlatest.html
Old Sep 6, 2005 | 04:16 PM
phorunninduke's Avatar
It is UNSAFE
Old Sep 6, 2005 | 04:23 PM
WATRD's Avatar
Blocks on the front axle are actually illegal in some states, including Washington.
Old Sep 6, 2005 | 05:35 PM
xcmountain80's Avatar
NO NO NO NO Please dont do this in theory it may seem like it will work but in reality it will be potentially bad if not fatal.
Aaron
Old Sep 6, 2005 | 06:06 PM
Ironmike4x4's Avatar
What's the story on the one from this board?
http://128.83.80.200/taco/scarysteering8.html
Old Sep 6, 2005 | 06:25 PM
EWAYota's Avatar
i was wondering the same thing.
Old Sep 6, 2005 | 06:45 PM
4Crawler's Avatar
thanks, Toy94ota
Besides the obvious safety issues, there is no room with stock steering. Add even one extra leaf to the spring pack and the drag link will likely bind up in the u-bolts, BTDT. I run a spacer that is welded to the driver's side spring perch on my front axle to level it with the passenger side perch:
With it welded to the perch and to the additional bracing added to the perch, it is in there fairly solid.
Old Sep 6, 2005 | 07:27 PM
WATRD's Avatar
With a bit of searching, you should be able to dig up the old threads that those pictures came out of. His pal was swearing up and down that it was perfectly safe and no amount of flaming by people who knew better was going to convince him otherwise... He was really proud of those.
Old Sep 6, 2005 | 07:34 PM
I wouldn't know what to search under. Custom lift maybe?
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
deepmarsh
Aug 6, 2015 03:44 AM
ItsJustD
Jul 7, 2015 07:49 AM
