Backspacing on 02 Taco?
Old Jul 7, 2005 | 09:30 PM
bamboo89's Avatar
i've decided what rims and tires to run, 17x8 6x5.5 rims with 285/70's and ran a search for the backspacing of the rims, but can't quite pinpoint the correct measurement i'll need for this combo. im not planning on taking it on trails, its just a DD, but would like to have to best backspacing to provide min. rubbing and would like to stay away from doing any mods to insure that there is no rubbing.
Heres a link to the Rims, http://www.4wheelparts.com/4wp/produ...WHEELS&man=ARE its a the 17x8 6 5-1/2
Thanks.
Old Jul 8, 2005 | 06:55 AM
4Crawler's Avatar
Grab a tape measure and a stick and measure one of your wheels and you'll know what the stock backspacing is:
Stick close to the stock backspacing to keep the tires in closer to the truck and minimize rubbing issues with the front tires when turnng.
Old Jul 8, 2005 | 12:00 PM
bamboo89's Avatar
aight i could like go out an inch or so from the spacing
Old Jul 8, 2005 | 12:29 PM
4Crawler's Avatar
You can generally run w/ less backspacing to push the wheels farther out from the body. Wider stance is nice with lift. However, for each inch less backspacing the outside of the wheel/tire is 1" farther out and for each extra inch of wheel width the outside of the wheel is 1" farther out and for each 2" wider tire, the outside of the tire is 1" farther out. The wider you go then wider the arc swung by the front tires is when you steer. If that arc intersects the arch of the wheel well, you'll need to trim or add lift to eliminate the rubbing:
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old Jul 8, 2005 | 01:14 PM
bamboo89's Avatar
so basically, say the backspacing is 4.5'' , i put the tire at 6'' so 1''of the tire will stick out, did i mention that im not gonna be offroading that all of this is for show um, think u couild help me out with finding a 3'' Fabtech Suspension lift for m truck its a prerunner and im needing to know what exactly i need to buy to lift it
Old Jul 8, 2005 | 01:21 PM
4Crawler's Avatar
Not quite, you might want to have a look at this page:
http://www.4crawler.com/Diesel/Tires.shtml#WHEELS
Everything is relative to what you have on there now. Scroll down that page about 1 screen and you'll see a detailed explanation of how to figure everything out. On the lift, you might contact a supplier of the kit, I'm sure they will be happy to assist you with any questions.
Old Jul 8, 2005 | 03:54 PM
bamboo89's Avatar
Aight, no prob, thanks for everything... appreciate it...
stanz
Oct 30, 2015 10:33 AM
Toys4parts
Sep 26, 2015 01:56 PM
theduck21
Sep 10, 2015 07:01 PM
rodskwad
Aug 12, 2015 02:33 AM
rap2me
Aug 11, 2015 05:03 PM
