2nd gen 1.5 lift -what shocks to run?
Old 07-23-2005, 08:12 AM
Y2Krunner's Avatar
i cant seem to find any info on which rancho or pro comp shocks to run with this small of a suspension lift? it seems like it should be so simple but i cant find anything and my local 4x4 shops cant offer any useful info. what do you guys run/think?
for my 92 4runner with specs see sig
Old 07-23-2005, 08:26 AM
4Crawler's Avatar
Here's some info I have collected:
The following are some possible shock absorbers that may work with a 1.5" front ball joint spacer and similar lift in back (longer spring shackles, add-a-leaf, coil spacer, etc.):
Rancho:
Front:
RS5167, RS9272
Rear/Coil:
RS5009, RS9009,
Pro-Comp:
Vehicle LIFT ES3000(F/R) ES9000(F/R)
86-95 4WD p/u 0"- 1" 314014/321506 914014/921506
86-95 4WD p/u 2"- 3" 317514/322506 917514/922506
86-95 4WD p/u 4" 318514/326506 918514/926506
KYB:
Front:
Rear: 317514
OME:
Front: N92(softer), N98(stiffer)
Rear/Leaf:
Rear/Coil: N72F
Old 07-23-2005, 10:00 AM
Blizzard's Avatar
Roger, he has a 92 4Runner so he has coils not leafs.
Y2Krunner, a friend of mine has the same coils I've (+4cm) and he put OME LC 80 coils and has a very nice flex:
He hasn't any BL and has 31's.
I want to put the same shocks but Ranchos, they're the RS99208 for RS9000's or the RS5208 for RS5000's.
David
Old 07-23-2005, 10:05 AM
Blizzard's Avatar
The 99009's are a little long (I think) without LC coils. I think they may bottom out...
RS99009:
Comp: 16.00''
Ext: 26.125''
Trav: 10.125''
RS99208
Comp: 14.625''
Ext: 23.250''
Trav: 8.625''
I know the 9208's are shorter but I think the 9009's will extend too much and the coil can move of fall and they can bottom out...
Anyone can confirm if they can bottom out with +1.85'' coils?
Thanks,
David
Old 07-23-2005, 11:28 AM
4Crawler's Avatar
Correct, that is why I listed rear shocks for both coil and leaf sprung applications.
Old 07-23-2005, 12:03 PM
Blizzard's Avatar
Ouch! Excuse me... I was a little asleep and only read some of the codes...
Old 07-23-2005, 12:27 PM
4Crawler's Avatar
I just keep one file for '86-'95 pickups and 4Runners. Fronts will be the same on all, rears on the 1st gen 4Runners and all the pickups will be the same, the 2nd gen 4Runner rears are the only different item, so it is not worth maintaining 2 or 3 different files with most of the information duplicated.
Old 07-24-2005, 08:56 PM
Y2Krunner's Avatar
im looking for something 1"-2" longer travel than stock correct, no longer no shorter? what is the stock travel for a factory 2nd gen 4runner shock anyways?
Old 07-24-2005, 09:11 PM
4Crawler's Avatar
Measure your shocks and see what the compressed and extended lengths are. Also, see how close to making out the extension you are now. Then you can see what sort of lengths you may need if you do need a longer shock. Info on how to all all the above are on the web page below:
http://www.4crawler.com/4x4/Rancho.shtml
Old 07-25-2005, 07:04 AM
Y2Krunner's Avatar
can i get an accurate measurement with them still installed or shall i take them off? and measurement is from eye hole to eye hole correct?
Old 07-25-2005, 07:12 AM
4Crawler's Avatar
To make the actual shock measurement, pull one off. Push it all the way in and get the compressed length, pull it all the way out for the extended length. Measuring tips on the page I posted a link to earlier. Then re-measure with the shock on the vehicle, see how close to full extension you are getting now.
Old 07-25-2005, 08:51 AM
Robinhood150's Avatar
A lot of people just use stock length shocks with the downey coils. Longer shocks aren't absolutely necessary. But...if you want better articulation then longer shocks are necessary.
Using rogers method of find the overall travel is a good technique, however the shock that fits that travel window (like the 5009) will be really long. The 5009 or 9009 from rancho will give the most amount of travel your stock linkages can handle, however you may find the springs will fall out...but I'm not sure. This amount of travel my be overkill for your application depending on how difficult the terrain. Also, with longer shocks you open up more cans of worms with the drive shaft hitting the gas tank and whether you need a panhard drop or not.
Even with cruiser coils, I'm pretty sure I would bottom out on the shocks way before I hit anything else.
Old 07-25-2005, 07:36 PM
Y2Krunner's Avatar
well i just installed my OME HD rear coils and with my old shocks measurement as it sat was 20.5" (from eye to upper shock mount). Will the 5009 still be overkill? i dont see the springs popping out as the multi link wouldnt let the axel drop that far... or would it?
Old 07-26-2005, 08:52 AM
Blizzard's Avatar
I have a doubt... You put longer coils (Downey, LC Coils...) but the distance between the shock mounts at full compress it's always the same... So if you put quite longer shocks (5009 f.e.) they would bottom out isn't it?
David
Old 07-26-2005, 10:09 AM
Yup. I haven't heard of any problems, although it is a concern of mine.
Old 07-27-2005, 01:32 PM
Blizzard's Avatar
I'm confused... I want to buy rear shocks next month when I go to Alaska and I don't know which ones take... 9009's or 9208's...
David
06-01-2021 01:51 PM
Avenged
07-09-2015 07:55 AM
MTLroadierunner
07-06-2015 12:17 PM
Steezy96yota
07-06-2015 10:00 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 2nd gen 1.5 lift -what shocks to run?
