View Full Version : Offroad Tech
Pages :
7]
10
11
12
13
14
15
16
17
18
- Driveshaft???
- the cheaper way to get lower t-case gears?
- Options on Transfercase Crossmembers
- breaking in front ring and pinion
- differences
- Tranny question
- Lifting a high mileage 4Runner?
- pre runner
- how to put the axle back on
- spring under axle kits?
- front chevy calipers
- so i got my OME leafs
- D60 carrier breaks
- discoverer stt?
- downey long travel
- Maximum CV travel
- OME 881 w/255's?
- gear/tire/speed/power/install confusion! What the hell?
- Where to mount MV-1050 and other questions
- Bolt-On or Weld-On D-Rings
- T-Max and Summit house brand winches info
- Twin stick or dual t-case?
- LSPV? bracket question
- Suitable Recovery Points?
- tires with 3 inch body lift.
- Spacer Lift Question
- using your winch to recover yourself.
- Manual hubs
- dual cases or 4 to 1?
- Biggest Tire w/IFS
- E-locker into a 94 4rnr....
- Thoughts on this downey setup...
- wheels
- Welding a V6 third
- gears
- LED bulbs
- High Pinion in the rear....
- disabling antilock brakes 01 Tacoma
- How about this suspension setup, good deal??
- Where did you get your D ring shackles?
- Anyone here have the lower first gear out of a turbo 4 runner in their 5 speed?
- toyota 4in lift kit what to get???????
- School me on fullsize axles
- backyard low pro bumps! + Coil spacer info
- Lower 2 + Gas Tank Skid= Funny
- mastercraft Courser MT
- Lockers
- Why is the Warn M6000 more expensive than the M8000
- Will 04 taco rims fit 04 4runner?
- 88 2wd truck with downey lift
- setting a TJM T17 up for a winch
- Transfer case gears and dual case Set up videos
- Axel swap
- My backyard budget boost!
- cruiser coils or ome lift?
- Problems lifting the front of '00 taco
- question about SAS for rock crawling/mudding
- Trail Gear VS Marlin Crawler VS All Pro Springs, whats best?
- Looking to add something...
- Jaos stuff in South Florida
- 2nd Gen Oil Pan swap and Hydro Assist install
- Hitch Mounted Recovery?
- 3rd member install, need some help and advice
- Rancho 44044 Springs, I need info about them!!
- Swapping Frame/Chassis?
- ARB solenoid question
- Lifting my 1997 toyota t100! need opinions asap!
- lifting my 81
- mixing a lift kit?!
- superlift vs skyjacker
- 255/85/16 BFG's?
- 2004 4 Runner V8 Limited Lift kit?
- What to do? My rear sway bar won't fit w/ retrofitted e-locker
- warn M8274-50 can this be right?
- Breaking in new rear diff
- rare situtation...removing a locker
- Front suspension maxed out. What do I do?
- saftey whip for dunes
- Rims/Tire Size Question 1st generation 4Runner
- ARB Bumper Question???
- 1.25" budget boost possible?
- coils for a third gen??
- 4 link rear 2nd gen using separate coil/shock setup?
- Diff oil for ARB locker?
- 1984 1/2 4runner Build
- pics
- Tires that wont SLIP....
- diff bolt torque values?
- WINCHES IN HELL COMPETITION see who won
- 3rd gen ARB compressor install (found ARB's weak link already)
- which hole does it go in?
- 1981 2wd Suspension/Drivetrain Options?
- Where to buy OME parts?
- some new tires for the pickup...watch out bigfoot
- Are lockers suitable for a 1996 2WD Toyota 4Runner?
- All toyota rear discs
- Tire Issue
- Lets setup a rear winch system...for my truck
- The Cheapest, Best way to Lift EARLY IFS trucks.
- Water in tires.
- front locker install?
- Dual cases vs ADD 4Runner
- 2006 4Runner 4WD
- 140 Lance or 170 Striker
- What do you carry on the trail?
- Syn. winch line protective sleeve placement?
- how not to recover from a rollover
- 1st Gen Runner Air Ride
- Tube Doors On A 2nd Gen Runner?
- 4.7's Are Awesome
- Long trip... Precautionary measures...?
- Anti-sway bar disconnects
- GM14T vs D60
- need to know what to do?
- Anyone ever see an axle like this before?
- Does my '97 Ltd. appear "stock" ride height?
- Sm465 to 21 Spline Toyota X-Case
- snorkle for a 93 p/u
- Input shaft spline, centerforce clutches, which one is best?
- Milemarker Solenoids
- Snorkel for CARB motor?
- Forced upgrade
- sm465 v.s turbo350 trans
- Someone tell me what this is? Diff skid or something...
- New Tacoma ..Need some advice and opinions
- buckets and lights installed
- Subaru STI seats in my 86 pickup?
- Looking for body armor...like the bottom of the doors/bed
- Spacers after new suspension?
- 3rd Gen 4Runner Suspension Setup
- Tires tires tires...
- Swapping 85 Truck Cluster for 00-03 MR2?? Ever been done?
- Well...got my first toyota pikcup! check this out.
- tundra trd or non-trd lift?
- Budbuilt Transfercase Crossmember Interference?
- How long to swap cabs on an 87 pickup?
- aluminum v.s steel wheels
- 1st gen 4runner rear glass
- Whats the 86 4runner worth? please help
- Need help
- Install help
- Front Suspension Help!
- stock rear gears
- Any pics of black limited 3rd gen lifted
- New BFG MT KM
- would any of you post a write-up on how to install the sonoran steel truss?
- Wheeling with an automatic transmission?
- My 4Runner got Bent Up!
- Warn model 500?
- '71 LandCruiser chevy 350 replacement Wiring Harness
- Fabtech 6" ????
- 33's Versus 35's Experiences
- I want more lift!!! HELP
- shocks hitting new springs
- Running a winch cable under your truck yes or no
- Toyota axle strength
- Lock rights front and rear...bad idea?
- Air bags with SAS rear leaves
- need help on lift
- ARB Bearing Failure??
- ttb v.s. ifs
- Need a winch...which one to get??
- rim protectors and beadlocks???
- Do I really Need a adjustable Panhard Bar? TJM makes one....
- TRD coil lift for 3rd gen 4runner, Tundra or 4runner top plate?
- Looking into using unimog axles as opposed to dana 60's
- Stock toyota rear leafs... why replace?
- Fj Cruiser
- I need some help on suspension for 03' DB 4x4
- 882s or Tundras on a stock double cab?
- Will 33x12.5 fit on a 2nd gen 2inch lift?
- TRD Tundra coils Double and Access cab any difference???
- Budbuilt---> BudBroke
- help with 3rd gen a-arms
- Im so confused
- Best diff mod for snow wheeling
- 2000 T4R - which OME suspension kit?
- help with body lift
- suspension 95 4runner
- gorilla winch?
- hey im new and i need experts help..
- Need Help With some running Lights i Installed
- 140K MILES on LC coils.... too much?
- Colorado Help
- 285's or 265/75 TIres with TRD/OME lift..PICS???
- Front locker for '06 Tacoma
- Sonoran Steel IFS Truss
- manual locking hubs?
- any tech on yj springs
- 99 4runner M/T's
- Build up Questions.
- rear shackle question
- TRD & OME or just OME Suspension Lift....Need to make decision!
- clarification on gearing my truck
- CV's are Toast ??? (with pics)
- Front spacer install
- Whats the best factory Spring and Shock Lift???
- Busted rear shock
- Any pics of 3rd Gen w/ 3" lift + 285's?
- 4wd spindle on 2wd
- 90 toyota 4in lift w/ 33's
- steering balljoint removal.
- Does this tire size exist?
- got my onboard air done
- Airing down question
- 4" TG SAS kit w/ OME 3-4" rear lift?
- Summit Racing KC Knock offs
- T-Max winches?
- WHO actually has the OME IFS Lift???
- The Official Ifs Sucks Thread
- clunking noise, Tcase sensor problem
- anyone know of SAS or engine swap shops in SOCAL??
- What do you carry? : Your trail spare parts and tools?
- 4runner sas is done but i have a problem and need your help!!!!!
- Body armour
- Long travel on 2nd gen runner?
- when adjustable track bar needed?
- ARB Operation Question
- Locker from 6cyl third to 4 cyl?
- How did you mount a hi lift to the TJM T15?
- Third Member unknowin gears
- Custom Rear Recovery Point
- Good low-draw inverter?
- Battery Isolator install question
- 20R problomes
- greasing bolt threads
- Marlin Crawler Case in new Tacos
- 85 Front axle repairs
- How low can (or should) I go?
- idler arm issues about to drive me insane!
- does anybody have the newer downey 3" lift
- 4.56's
- Lift time comin up
- New Coil SAS
- More under axle clearence
- How do I know what gears I have?
- Turbo automatic transmission upgrade question
- looking for guages like mitsubishi monteros have
- How well does a well built SAS rig really drive on the highway?
- MM winch mount grille guard
- viberation
- OME Suspension Upgrade
- Newbie Helmet, Seat and Equipment Questions
- Locker Install Write Up
- tranny swap, manual or auto
- Idle Issues on 1990 3.0 V6
- What Should I Buy Next?
- Total Noob Move on my part...view the pic.
- Broke a birf now steering sucks
- 90 toy fuel pump ques. and fuel guage
