OEM Carrier Assembly Locker or lockright?
Old Jun 24, 2005 | 04:52 AM
rngrchad's Avatar
Is the Toyota OEM locker a good choice for serious offroad explorations? How does it compare to say a lockright? I have a situation where I can purchase the OEM toyota locker for a little more than a lockright. Opinions welcome.
Thank you
-Chad
Here is a schematic of the oem locker:
http://www.trademotion.com/partlocat...=6&catalogid=1
Old Jun 26, 2005 | 12:59 PM
05TACODOC's Avatar
I'm on my second Taco with the OEM locker. I flogged the first one quite a bit w/o breakage, a good unit IMO. I would recommend it
Old Jun 26, 2005 | 01:29 PM
jimbo74's Avatar
the toyota oem locker is cool, however it has 1 weakness in my opinion, the actuator is huge and sticks out..... several companies do make a skidplate for it though so it wont get hung up on anything..... the performance from all i have seen is flawless on it.... what vehicle will you be putting the e-locker in? you must make sure that it is compatible first.... they are not a direct swap into the older vehicles but can easily be put in after modifying the housing a little bit and the tacomas that were not equipped with the e-locker had a whole different sized axle
Old Jun 26, 2005 | 07:54 PM
Cedarbarn's Avatar
***I am not an expert at what part will fit what by any means.***
The information I have learned is that the E Locker will not work with a Non E Locker axle. You will also have to work with the wiring harness...
I am going with the Lockrite in my truck.
Old Jun 26, 2005 | 08:01 PM
jimbo74's Avatar
that is why i said what i said above.... the e locker will work in a non e locker equipped truck if the housing is modified via this writeup: http://www.4x4wire.com/toyota/tech/electric_locker/ dealing with the harness is an easy fix, tons of companies sell kits to deal with this issue
the elocker from a toyota 8" will not work in a tacoma that was not equipped with an elocker
Old Jun 27, 2005 | 05:45 PM
Cedarbarn's Avatar
Thanks, learn something new everyday!
Old Jun 27, 2005 | 07:57 PM
Ironmike4x4's Avatar
What ever happened to the writeup in the tech section about retrofiiting the e-locker? From what I understand, the non equipped 4runners can be retrofitted with the e-locker without having to modify the housing? I asked this before but no one seemed to know.
Old Jun 27, 2005 | 08:03 PM
kyle_22r's Avatar
only trucks with the T100 style rear end can't be retrofitted with the locker(non TRD tacomas, T100, tundra). the 4runner has always used the standard 8" rear end, and therefore can be modified to run the e-locker. non-trd tacomas have a T100 style rear end, while the TRD trucks have a standard 8" equipped with the locker.
Old Jun 27, 2005 | 08:06 PM
jimbo74's Avatar
ironmike4x4, i have enver heard that the locker could be outfitted into an 8" without modification in a truck that didn't already have an elocker......
Old Jun 27, 2005 | 08:13 PM
I know we are talking about the trucks but I was thinking about the 3rd Gen 4Runner. I don't know that's just why I'm asking. I would figure since it was an 8" it should go right in but then again I don't know.
Old Jun 27, 2005 | 08:17 PM
jimbo74's Avatar
if it is any 8" rear that was not equipped with an elocker, the housing needs to be modified
Old Jun 29, 2005 | 08:29 AM
Simple enough answer, thanks again Jim.
Old Jun 29, 2005 | 03:03 PM
gwhayduke's Avatar
I always wondered about the e-locker in wet and muddy conditions. Noticed that Downey now sells a cable to manually actuate the e-locker. Of course, you have to dump the electrics.
Old Jun 29, 2005 | 06:53 PM
rngrchad's Avatar
For what it's worth guys, I just decided to buy the lockright. It's going in tommorow night. Good info fella's but even w/ a massive toyota oem discount I still couldn't justify the pain in the ass install and the price difference. Thanks anyhow.
suppra87
Jul 15, 2021 05:15 PM
1uzRunner
63
Nov 10, 2018 03:58 PM
G-off
Dec 29, 2015 12:44 PM
Regency
Sep 6, 2015 05:47 PM
Nick Berg
Sep 3, 2015 04:36 AM
