weight on fj80 coils
Old Aug 20, 2005 | 11:11 AM
TimJo85's Avatar
im lookin at buy some fj80 coils(used) from aw100 on here and i have two questions bout them
will they give me 3.5" of lift in the rear?
i have two 12" subs in the back and they are in two heavy long ported boxes will they make the coils go down any and not get a 3.5" lift out of rear?
for the front im gonna get 1.5" bj spacers and crank tbars a lil and get manual hubs and pan hard drop bracket.
does all this sound good?
also i been look for manual hubs online and all i can find are some warn hubs that are like $150 is there any where else i can get manual hubs?
thanks
Old Aug 20, 2005 | 11:12 AM
TimJo85's Avatar
oh yea i got a stock 1994 4runner right now with 4.88 gears...im gonna put 33x12.50 tires on it after lift
Old Aug 20, 2005 | 12:16 PM
4Crawler's Avatar
The lift you get out of the FJ-80 coils will be whatever you get. Depends on the weight in the back of your rig, the spring rate of the coils and how much use they have seen. Look for used Aisin hubs on-line at http://www.ebay.com/ or http://www.car-part.com/ or http://www.yotayard.com/ or heck even http://www.taprecycling.com/
Old Aug 20, 2005 | 04:56 PM
TimJo85's Avatar
are there any other ways to lift the rear 3.5"? b/c i got the front with 1.5" bj spacer and then i was gonna just crank t-bars up a lil to make it even with rear....or is there a better way to lift the front as well?
Old Aug 20, 2005 | 05:08 PM
4Crawler's Avatar
Your best option is put the coils in and see what you end up with, lift-wise. Then since you are cranking up the front to match the back, do so and you will be fine. Who cares if you get 2.936" or 3.497" of lift, you set the front to match the back. It is not like there are lift police running around checking your truck and if it is not exactly 3.5" taller than stock, they are going to write you up!
I do not think there is any way you are going to get 3.5" out of the front end with the spacers and the torsion bars, at least something useable, but you are welcome to try. So if the rear comes in a little under 3.5", that is a good thing, your front suspension will thank you!
Old Aug 20, 2005 | 05:23 PM
TimJo85's Avatar
yea b/c im gettin the fj80 coils from aw100 on here for $60 and that will save me some money...and i can fit 33x12.50
Old Aug 20, 2005 | 05:32 PM
4Crawler's Avatar
You don't "need" 3.5" of lift to fit those tires, especially in back. 2" - 3" is plenty. Here is a writeup on a 2nd gen 4Runner w/ a very low lift running that size tire:
http://www.off-road.com/toyota/rockr...ons/33/33.html
Old Aug 20, 2005 | 05:46 PM
TimJo85's Avatar
i was lookin at manual hubs on ebay and i remeber u sayin that any hub would work on my 94 4runner auto. that was 4x4 and between 86-95 is that right i could get like and 88 ford manual hub or somethin and it would fit and work perfect on my 94 runner also do the manual hubs have to match each other
thanks
Old Aug 20, 2005 | 05:49 PM
TimJo85's Avatar
ex there are two old manual hubs on ebay from a 88 ford f-250 they look ruff but say they work good....could i get those(they are cheap) and would they work fine on m 94 4runner?
Old Aug 20, 2005 | 05:53 PM
4Crawler's Avatar
Sorry, I guess I should have stated the obvious, any 1986-1995 (IFS) TOYOTA 4WD PICKUP OR 4RUNNER FRONT LOCKING HUB. You don't want the solid axle hubs (1985 and older) and you don't want the 1995.5 and later Tacoma and 3rd gen 4Runners hubs as neitehr of those will fit.
Old Aug 20, 2005 | 06:03 PM
TimJo85's Avatar
ight so its gotta be IFS toyota...my bad....thanks for all the help
MadMax48
Mar 3, 2020 10:33 AM
the_supernerd
Oct 1, 2015 09:20 PM
mojo4x420
Sep 16, 2015 08:07 AM
