Wiring 2nd set of lights
Old Aug 24, 2005 | 12:24 PM
01Mossy Oak edition's Avatar
I want to tie in my new Hellas to the parking ''side marker'' lights.
What color wire do I need to tie into???
Thanks
Old Aug 24, 2005 | 01:44 PM
Ironmike4x4's Avatar
Why? Do you want them to turn on when you turn on your park lamps?
Edit: I tried to get some wiring diagrams online but could not find the schematics for the park lamps.
Old Aug 24, 2005 | 02:23 PM
4Crawler's Avatar
I wired my fog lights like that on my 1st gen. The parking light circuit powers the relay for the fogs, a separate switch grounds the relay to turn it on. Power for the fog lights comes from a separate fuse I added off the battery.
Which wire to use? Easy way to find out, measure voltage on one of the wires when the lights are on, if it is 12V, use that one, otherwise, use the other one. That is how I did it on mine. Takes more time to explain it that to do the check, actually. Or, no volt meter? Pull out the bulb and if it is the kind with a metal base (ground) and center contact for power, find out which wire connects to the center contact in the socket and use that wire.
Old Aug 24, 2005 | 03:34 PM
Thanks for clearing that up for me Roger.
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
colinmil
Jul 6, 2015 04:03 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
Steezy96yota
Jul 6, 2015 10:00 AM
