Body or Suspension?
Old Aug 30, 2005 | 09:51 AM
jtm994's Avatar
Body or Suspension?
Which is better for you truck in the long run body or suspension lift?
Old Aug 30, 2005 | 10:36 AM
humanoid's Avatar
It all depends what you want to do with your Runner. Street queen or wheeler?
Old Aug 30, 2005 | 11:49 AM
jtm994's Avatar
this one would be a street queen
Old Aug 30, 2005 | 06:23 PM
humanoid's Avatar
If it's a street queen then I believe a BL would be fine... that is if you don't mind seeing a bit of your frame showing.
Old Aug 30, 2005 | 07:03 PM
Magreger's Avatar
BL buddy
Old Aug 30, 2005 | 11:24 PM
deathrunner's Avatar
I'd do a mild suspension lift. bj spacer and a rear spring pack. with shocks you will probably spend 4-500.00 and it will ride and function much nicer than a body lift. A body lift would probably costs just as much if you have someone else install it.
Old Aug 31, 2005 | 03:53 AM
waskillywabbit's Avatar
Which toothpaste do you prefer as they do different things for different reasons for different people?
There are TONS of threads on body lifts, suspensions lifts and more.
A good place to start is by doing a "search" for "Lift FAQ" and do some reading.
I have both. 5" of suspension lift to clear bigger tires for more ground clearance and flex etc. and a 1" body lift to help w/ clearance issues for things such as custom bumpers, t-case (going to duals eventually) and to get more clearance for my tires.
It all just depends on what you want...there isn't a one size fits all box answer.
Old Sep 2, 2005 | 11:29 AM
JGM's Avatar
JGM
I'm confused - from your signature it looks like you have both on your 2nd Gen. Just looking for other opinions?
Anyway - I'd also look at age of the current suspension. A BL isn't going to help with the inevitable butt-sag of the long-lasting 4R.
Old Sep 4, 2005 | 07:33 AM
geneius's Avatar
Street Queen? I'd say BL. You can do a 2" for about $160 or so IF you're turning the wrench.
With a suspension, you'll definitely be spending about $500 for coils and shocks. You may also want to consider manual hubs to keep the wear off your CVs.
Jun 1, 2021 01:51 PM
nvdesertrunner
May 11, 2020 08:18 PM
Sep 4, 2015 09:27 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
Vargntucson
Jul 4, 2015 12:15 PM
