Shackle Hangers, for cheap?
Old Jul 7, 2005 | 03:19 PM
Gangus2006's Avatar
Since I cant afordd to lift the 4Runner, and get better tires, right now to help me from getting stuck, Im gonna get some recovery pionts for when I do get stuck.
Where can I get some Shackle hangers/Shackles for cheap? Cheap as in <$100 would be awesome.
Also, aside from a tow hitch shackle hanger, what could I use as a recovery point out back?
Old Jul 7, 2005 | 03:21 PM
jimbo74's Avatar
get some towhooks and mount them to the frame.....
depending on what the rated strength is, you can get D shackles at the hardware store.....
Old Jul 7, 2005 | 04:05 PM
Mojo_Risin's Avatar
agreed - $8 dollar tow hook at any autoshop is what I have for recovery point on back. Used it several times (to pull people out)
or for a few more bucks get one with a clip so the tow strap won't fall out.
John
Old Jul 7, 2005 | 04:51 PM
Gangus2006's Avatar
John
Now, with those, Im assuming Ill have to drill the frame?
Old Jul 7, 2005 | 04:55 PM
Mojo_Risin's Avatar
Shouldn't have to - there is a stock "loop" If I remember correctly already attached to the frame - just take that off and put this on. Or there are already holes. I can't remember. All I know is I definately didn't drill into my frame.
John
Old Jul 7, 2005 | 05:04 PM
jethro's Avatar
You could get these from Warn for around $18 each and run them through the "loops" on the frame, requiring no drilling.
Or go to your local boating store and look by the anchors for some cheaper galvanized shackles. There's a Boaters World about 50 miles away from you in Danvers if you're up for the drive.
Old Jul 7, 2005 | 06:53 PM
Fink's Avatar
WARN also sells a receiver shackle...that will run you clost to $40. I got mine from Cabela's.
Fink
Old Jul 7, 2005 | 07:22 PM
rngrchad's Avatar
Go to TSC. You can get 20,000lb rated weld-on shackle hangers for 9 bucks. I've welded these shackles to my flatbed that tows a huge bobcate and tractor. I also have these same hangers on my bumper. I'll post pics if you are interested.
Old Jul 7, 2005 | 08:19 PM
ianshoots's Avatar
Chad, I assume TSC=Tractor Supply, yeah?
EDIT:I check out their site, search shackle hanger and shackle mount, didn't find anything-any idea what they call 'em? Maybe I'd just have to hit a store.
Old Jul 8, 2005 | 09:00 PM
rngrchad's Avatar
Ian, yes Tractor Supply. They have them in their retail stores for around 10 bucks or something. Stout shackles, I Arc welded some onto a flatbed work truck and crank the pi$$ out of chains while strapping our equipment day in and day out. They won't break.
The shackles were in the isle w/ the tow straps and winches.
hope this helps.........
Old Jul 9, 2005 | 01:46 PM
Gangus2006's Avatar
By loops, you mean the tie downs? Would that be any strong?
Old Jul 9, 2005 | 01:57 PM
4Crawler's Avatar
Sonoran Steel has these:
http://www.sonoransteel.com/store_shackle_hangers.html
I made my own receiver shackle hanger a few years back:
Old Jul 10, 2005 | 06:40 AM
Napoleon047's Avatar
while the ones like roger has and warn sells are kinda cool, they are a complete waste of money IMO, if you have a reciever hitch, just put the loop into the reciever and then put the pin through the loop.
Old Jul 10, 2005 | 06:49 AM
4Crawler's Avatar
On my bumper, I have deep receiver pins, so it is hard to get the strap shoved in that far (my pins are 5" back vs. 2.5" standard). Plus there is the worry of the sharp edge of the end of the receiver damaging the strap on angled pulls. Also, sometimes there is no loop available or you need to hook up something other than a tow strap, so a shackle is a nice thing to have available. But yes, the hitch pin through the strap eye is often all you need.
jb451
7
Oct 7, 2022 06:58 AM
vikinghug
Jun 14, 2016 08:10 PM
pickle6415
Oct 19, 2015 08:08 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
oldblue
Sep 28, 2015 04:07 PM
