Trouble Shifting into 4wd
Old Apr 2, 2005 | 10:33 AM
2WICE's Avatar
Guest
From: Las Vegas.. Soon to be heading for south america in the 4R
1992 4runner SR5
last ngiht i ran opver a rock after making a stupid mistake and not walking a downhill before going over the edge (wasnt to steep.. but a 2 foot rock was in the trail)
now i cant use 4wd unless i work it hard.. and hold the 4wd lever in place.
also all the gears on the tranny are a little off when shifiting (auto)
banged the tranny really hard, and the transfer case got hit bad too..
any clues for me?
can send you pictures if you want..
Old Apr 2, 2005 | 01:37 PM
4Crawler's Avatar
Sounds like you may have bent the transfer case shift linkage. Climb underneath and give it a once-over. It is adjustable, so find out what is holding it up and see if you can adjust/bend it back to normal operation:
http://www.4Crawler.com/4x4/ForSale/...tomaticTranny1
Old Apr 6, 2005 | 10:44 AM
2WICE's Avatar
Guest
the only thing i can see that could be activly holding the transfer case up is the peice of frame cross member that slips right under the problem area. it got banged a lil over half an inch up.. suggestions?
Old Apr 6, 2005 | 11:09 AM
4Crawler's Avatar
Bend it back down?
Old Apr 7, 2005 | 08:27 AM
2WICE's Avatar
Guest
how can i bend it.. iv tried prying it.. and i cant find anything to pry against that i dont think will break through.
thanks for the help
Old Apr 7, 2005 | 08:31 AM
4Crawler's Avatar
Not sure exactly what is bent, but one option is to take the part off and bend it off the truck. Or get a replacement for the bent part at a junkyard if you think the damaged part is the cause of the problem.
Old Apr 7, 2005 | 09:55 AM
2WICE's Avatar
Guest
good ideas.. thanks a lot.. all the parts i have issues with i wanted to upgrade at some point in time.. this might speed the process up
Old Apr 7, 2005 | 06:41 PM
deathrunner's Avatar
allpro sells a bitchin transfer crossmember that includes thier disc brake parking brake. It's on the front page www.allprooffroad.com
Old Apr 7, 2005 | 07:37 PM
surelly09's Avatar
Bud Built also makes an AWESOME!!! crosssmember. He does great work and works with you. He can also bend a drive train lift into the crossmember when you order it. He also has a couple of different skid plates.
www.budbuilt.com
here is a couple of pics comparing the stock and budbuilt crossmembers:
And a pic of it installed:
Fine craftsmanship!!!!! It went right in and fit prefectly!
Jayboy74
10
Dec 21, 2021 08:27 AM
mskalmus
May 28, 2017 07:51 AM
skoob
Oct 15, 2015 03:23 PM
mund1011
Aug 16, 2015 07:10 AM
jgwerth
Jul 16, 2015 03:23 PM
