Stupid Noob lol
Old Mar 27, 2005 | 03:19 PM
Lone4runner's Avatar
Stupid Noob lol
My first mistake going w/o anybody on a muddy muddy trail with a stock 4 runner sigh. need to mod badly thinking of
upper control arms chaos fab
saws 2.5" lift
ome 891 in rear
33" m/t brigdestone tires
hmm anything else? recomendations???
id post some pics but it keeps telling me size is too big no mater what type of format
Old Mar 27, 2005 | 04:18 PM
kyle_22r's Avatar
what was your problem? high-centering, or just total lack of traction?
top of the list should be at least a rear locker. lockers will get you farther than any other modification.
Old Mar 27, 2005 | 04:22 PM
may i ask what a locker would have done in this case? i had no traction what so ever my front end dug itself into a hole. again im still new so im not sure if what a locker would have done. cause i couldve sworn all my tires were running cause i locked my center diff. all reponses appreciated : )
Old Mar 27, 2005 | 04:28 PM
photoleif's Avatar
still stuck? or just a close call? you oughta consider a winch and $300 of recovery gear if you're the go-it-alone-in-mud type ;-) re the tires, if you'll be doing a lot of muddy trails, you're on the right track with the MTs. a lot of folks really like the BFG MTs as well. you oughta be able to clear the 33s with the 2.5" lift. i did 5" and mine look puny... then again, i was also thinking of 35s at some point, so doing a bigger lift now was probably the right approach. lockers would help in terms of controlling the spin and getting you through some more challenging areas, but since you don't have a sig i can't tell what you are driving. if you're gonna be in there doing the TC UCA, why not also do the lower BJ uniball conversion too... my lower BJs were going out all the time, so hopefully this will take care of it. then again, with all this stuff, why not just go for the TC "caddy" susp system? it's all of this, gets you some serious lift, does 6" offset (3/side), makes you ready to clear 33s and does some serious conversion and beefing up of your IFS. initially i didn't opt for it because of the cost, but overall my lift cost ended up comparable anyway, and i don't have the full TC setup. grumble, grumble. just my 2¢...
Old Mar 27, 2005 | 04:31 PM
ChickenLover's Avatar
By 'locked my center diff' do you mean transfer case? Were 99's equiped with variable tc's? The rear locker kyle is refering to is a rear diff locker. When engaged it provides 100% traction to both rear tires. Instead of just one, as in an open diff.
Old Mar 27, 2005 | 04:33 PM
WATRD's Avatar
Locking your center diff doesn't make power go to all four tires. See this thread;
https://www.yotatech.com/forums/f2/standard-center-diff-lock-55156/
It just makes and equal amount of power go to the front and rear, but since your diffs are open, it gets wasted anyway
Unless you were high-centered where your rig is sitting with all it's wheels off the ground, lockers in the axles would have improved the situation.
Old Mar 27, 2005 | 05:36 PM
variable tc"s. if you are referring to lo wrange and high i have that
Old Mar 27, 2005 | 05:38 PM
thhis was definitely a close call i new someones brother who had a modified truck who was able to pull me out but one thing was for sure i new i didnt belong off road w/o the proper euipment at least a better set of tires for mud. i have the revos which did nothing
Old Mar 30, 2005 | 09:22 AM
Crux's Avatar
What year 4Runner?
Old Mar 30, 2005 | 09:44 AM
4Hummer's Avatar
Get yourself a HiLift Jack.
You can use it to Winch yourself out and to lift your vechile outta the mud to stick stuff under the tires.
You can pick up Hi Lifts for under $100.00
Old Mar 30, 2005 | 01:42 PM
William439's Avatar
First off, always go out with at least one friend
Second, if you weren't high centered then go with either a winch or a locker. The winch if you plan on getting stuck alot or going out with no one else again. The locker is if you want to be impressive. Course a locker will be helped tremendously with the addition of some good offroad tires like mud terrains.
My recommendation is to go out with some friends buy the lift and the tires so when you do get stuck you have someone to help you out and then when you get enough money, re-gear and lock the diffs or buy an offroad bumper with a winch. If you like going out alone buy the winch, if you are going to continue going out with friends, buy the lockers.
Old Mar 30, 2005 | 06:40 PM
its a 99 4 runner limited. yeah i should go out with some frineds tough to find out here in boston though lol. i just got to antsy i should have waited. hi lift jacks are a definite on my wish list. unfortunately this time i had no where to winch it was kinda like a swampy area
pickle6415
Oct 19, 2015 08:08 AM
voiddweller
Oct 2, 2015 07:47 AM
hiluxinargentina
Sep 30, 2015 11:12 PM
PNW94Runner
Sep 29, 2015 02:55 PM
Rickstwowheels
Sep 29, 2015 02:23 PM
