just bought medium OME coils
Old Apr 23, 2005 | 08:15 AM
callmej75's Avatar
*UPDATE* just bought 901 OME coils
a pair of 901 OME rear coils from Phil at Toyota of Dallas. i usually don't tow alot of things but if i do it shouldn't sag as much as my stock springs did! i'm really considering the doetsch tech prerunner shocks that have a half firm ride so that will help me out a little with towing if i need it. maybe next week ill get 4crawlers bj spacers and my 1" diff drop ill post pics before and after the ome's are on. im hoping after the bj spacers and diff drop is in that i can crank my torsion bars way down to give me that extra comfort up front that i've missed!
Old Apr 23, 2005 | 09:43 AM
Paul H.'s Avatar
Thats what I have on my rear and they are a big improvement over stock. Cranking the torsion bar up front will not improve comfort only good shocks and tires will do that will do that.
Old Apr 23, 2005 | 09:46 AM
callmej75's Avatar
i have the torsion bars cranked up right now to clear these 31x11.50's. im hoping that the diff drop and bj spacers will level me up with the rear while i crank the bars back down.
Old Apr 23, 2005 | 11:02 AM
Randomness's Avatar
OME's are a great choice I love my HD ones.
Old Apr 23, 2005 | 11:04 AM
callmej75's Avatar
does the hd seem stiff?
Old Apr 25, 2005 | 06:47 AM
Strap22's Avatar
Sponsoring Vendor
I am running the 901 HD OME springs and have sold alot of sets to Yota Tech members. I have had no complaints and I really like the fact I can carry alot of weight without worrying about a saggy butt. Im sure your 900 OME will be just fine. If they do sag you may want to consider adding a rear spacer.
Here is a link to a rear spacer:https://www.yotatech.com/forums/show...91&postcount=1
Old Apr 25, 2005 | 07:02 AM
callmej75's Avatar
I should have ordered the 901's but i was thinking of ride quality on the highway...but if i got a softer shock then that would compensate a little with the stiffer springs...right? the 2" spacers sound good...but unfortunately here in VA the law is 24" from ground to bottom of bumper and right now i am sitting 28" in the front and 20" in the rear.
Old Apr 25, 2005 | 07:24 AM
Strap22's Avatar
Sponsoring Vendor
2" spacers will only lift you 2"more. That should put you at 22". If 24"' is the legal height you could add this without any problem. Good luck with your project and let me know if I can help..............
Old Apr 25, 2005 | 07:27 AM
callmej75's Avatar
well i just called in for the status of my order and they say i only ordered 1 coil spring for $70...so I canceled it since I ordered on a prepaid credit card and i don't have the funds there to cover it til this evening. i was looking at all pro offrroad's coil springs for $119 and they say they are heavy duty...
Old Apr 25, 2005 | 07:34 AM
Strap22's Avatar
Sponsoring Vendor
I sell the OME901 H.D. springs for $117.64 per set plus shipping. Give me your zip code and I'll qoute you for total priced shipped.
Hope this helps............
Old Apr 25, 2005 | 07:37 AM
callmej75's Avatar
awesome! 24301...i have $126 on my card at the moment...its a Virginia zip code
Old Apr 25, 2005 | 07:47 AM
Strap22's Avatar
Sponsoring Vendor
Freight to you is $18.00. That's $135.64 to your door. That's the best I can do. If you place your order now I'll process it on Tuesday so you have enough time to get another $9.00 in your account. What did you do about shocks? OME N72F for the rear and N98 for the front are what I would suggest. They are $129.70 a pair. That is the setup I am running and it is what OME recomends.Let me know if that will work....
Old Apr 25, 2005 | 07:56 AM
callmej75's Avatar
i am buying some doetsch tech prerunners because i plan on doing some pretty intense off roading when i get everything set up. how much lift do you have on your 4runner? looks pretty damn good! how could i place my order for those springs?
Old Apr 25, 2005 | 08:06 AM
Strap22's Avatar
Sponsoring Vendor
Send your request to:www.info@trdparts4u.com with a number to reach you at. We will take your Prepaid card info and hold the order till Tuesday so you can deposit $9.00 more. I really appreciate your business and if we can help you with any other parts or info please let me know.........
Old Apr 25, 2005 | 08:11 AM
Strap22's Avatar
Sponsoring Vendor
With the OME kit and 33's I have about 4" over stock.
Old Apr 25, 2005 | 08:31 AM
callmej75's Avatar
looks like more than 4" over stock...but it looks good! just submitted my order thru email and I just got a confirmation that a Barbara King received it.
Old Apr 25, 2005 | 08:51 AM
Strap22's Avatar
Sponsoring Vendor
Excellent..........Send me some pictures when you get it done. Thanks for the business.
Old Apr 25, 2005 | 08:57 AM
callmej75's Avatar
will do! thanks for the service Phil! When I get the pics where do I send them? What shipping time am I looking at? Its taking 8 days to get a taillight from california as we speak.
Old Apr 25, 2005 | 09:06 AM
Strap22's Avatar
Sponsoring Vendor
You should get them by Friday. We are also are a Toyota Dealer and can get you any parts you need. Our hard parts site is: www.toyotapartsales.com
You can use it to compare prices and to look at pictures for some of the items.
As for the pictures when your done....just post them here. I am sure others would like to see them as well.
Old Apr 25, 2005 | 09:13 AM
callmej75's Avatar
true...hey while you're here I cannot find this part because i don't really know the name of it and i don't know the part #. Its the part that is on top of the center timing idler that lets coolant flow thru it. Its currently leaking and I changed out my timing belt and idlers...but i got silicone gummed on it right now and its leaking more every day. I also have a leak at my steering box and I need a seal. Its the seal that is on the box that leads to the shaft going to the steering column. Can't seem to find it anywhere in auto parts stores here. thanks again!
