Yet Another 1997 4runner Rear Question
Old Apr 14, 2005 | 05:53 AM
BOSTON4RUNNER's Avatar
I hate to be a pain, and appreciate the help, I need to move quick on this..
did they make an e locker or other locker in a 4 runner with 4:10's???
a salvage yard near me says they have a locking rear for a 1998 4 runner..and it has 410 gears
tim
Old Apr 14, 2005 | 06:27 AM
calg3's Avatar
If it says RR DIFF LOCK by the steering wheel then it is the e-locker. I like the gear chart Steve has on his website:
http://fastq.com/~sschaefer/Toyota_axle_codes.html
and I found this on J.A.'s 4Runner History site:
"4.300 w/ optional P265/70R 16 tire package
and all models with locking rear differential "
1998 only came with the e-locker to the best of my knowledge.
How much do they want for it?
Old Apr 14, 2005 | 06:49 AM
too much... 1000!!
Old Apr 14, 2005 | 05:10 PM
calg3's Avatar
Originally Posted by BOSTON4RUNNER
too much... 1000!!
Whoa! Way too much!!!!
Old Apr 14, 2005 | 07:03 PM
got mine apart tonight
found the axle bearings at the local store for 60 bucks each
going to order the power trax tomorrow
all else looks fine on the rear end in my truck, ring and pinion is nice, but the axle bearings/wheel bearings at the end of the axle tubes,,where the axles bolt in
COMPLETE junk, like you wouldnt believe how they are falling apart,,one side if you have the axle sitting on the ground, you can move it 2 inches either way independent of the backing plate,,,i will also replace the outer axle bearing on the other side (driver side) which is also a little noisy
has anyone installed a power trax? was installation easy?
Jdgarrison
Oct 1, 2015 05:22 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
CJ94yota
Jul 3, 2015 10:14 PM
