OME 901HD Questions
Old Apr 25, 2005 | 02:46 PM
914runner's Avatar
OME 901HD Questions
Hello all, Im looking for some new springs because my Downey's are sagging.
The reason they are sagging is because I always have about 300+ lbs. in the back with my cargo box and regularly haul a heavy trailer, my fear is that they will only get worse when I put on my custom bumper.
So I was reading about the OME 901HD's. Are these springs stiffer then the Downey HD's? From the sounds of things, they are but I just wanted to make sure.
My only other option is tho put on my short side LC 80 coils that I have but I think they will be too tall for what I want.
Now what shocks should I run? Are the rear OME shock's (N72F's) just a stock spec shock with better valving or do they allow for more drop? Would I be better off just running some regular 5100 series 10" or 12" travel Bilstein's?
Thanks
Old Apr 25, 2005 | 03:40 PM
Strap22's Avatar
Sponsoring Vendor
The OME 901 is a very stiff spring. How it compares to a Downey I am not sure. All springs sag over time but the amount varies depending on how they are used. From what you discribe and not knowing how much tongue weight your trailer has or the overall weight of the trailer you are hauling I can only say I have hauled alot in the back of my '91 with OME901's and they are still about the same as they were when I put them on. I expect them to sag some in the future. I guess I am not much help on this one but would be happy to hook you up with a pair of OME901's. We sell them for $117.64 plus shipping. Let me know if I can help..............
Old Apr 25, 2005 | 03:52 PM
914runner's Avatar
It probably doesnt help that I bought my Downey's used from Adrian, who used them for rock crawling (lots of flexing), and that I flex them quite a bit too. I have heard that over time that also causes springs to sag.
Old Apr 25, 2005 | 03:53 PM
914runner's Avatar
How much lift will the 901HD's give over stock (non sagging) rear? The Downey's give something around 2" I thought?
Thanks
Old Apr 25, 2005 | 03:55 PM
Strap22's Avatar
Sponsoring Vendor
That's about the same. With my 33's I am alittle over 4" from stock.
Old Apr 25, 2005 | 03:58 PM
Randomness's Avatar
The OME shocks (N72F and N98) are long travel shocks, and they work best with the OME coils, I think.
Old Apr 25, 2005 | 04:03 PM
914runner's Avatar
How much longer are they extended?
Thanks
Old Apr 25, 2005 | 04:18 PM
914runner's Avatar
I was just thinking. I could go to the wrecking yard I go to and get a pair of LC 80 series rear shocks and see if those will be co long when compressed and if they give my the drop I want. Then if they work I could just get some standard length LC80 OME's.
So what do you guys think of that idear?
Thanks
Old Apr 25, 2005 | 05:57 PM
byron4's Avatar
are the OME HD coils so stiff that the smoth ride dissappears/ apoligies for the high jack.
Old Apr 25, 2005 | 06:44 PM
914runner's Avatar
My rig never has had a smooth ride, I consider my rig as a truck because it rides like a truck and I use it as a truck! lol
So my guess is at first they would ride quite stiff, especially with little to no weight in the back.
Old Apr 26, 2005 | 10:16 AM
Randomness's Avatar
No, I think it rides pretty smooth. The shocks play a big part in the smoothness, too.
nvdesertrunner
May 11, 2020 08:18 PM
he's gone
7
Dec 3, 2019 07:08 AM
punks_is_4x4
Aug 21, 2015 01:35 PM
Luvmeye22re
Aug 4, 2015 03:53 PM
4Runnin2000
Jul 29, 2015 06:09 PM
