FROR 2nd gen 4Runner discos...
Old Mar 30, 2005 | 12:36 AM
4RunnerKid's Avatar
got my FROR sway bar discos in finally... i think these are the first ones, actually. it took a while to get them, but they are quite sweet. i doubt these will ever fail me. at least i hope not. they should be installed tomorrow or the next day. i'll post those pics when i get them, and let you guys know how they hold up. for now:
Old Mar 30, 2005 | 04:35 AM
Marc P's Avatar
Those are sweet--How much are they going for??
Old Mar 30, 2005 | 05:47 AM
Praufet's Avatar
I don't get why one end isn't welded on and the other have a pin as opposed to both end having pins. Also interested in the cost.
Old Mar 30, 2005 | 01:28 PM
4RunnerKid's Avatar
i believe they are going for $149... or something like that.
Old Mar 30, 2005 | 04:07 PM
Praufet's Avatar
roger sells some, 80 + something for the right angle adapter. Look the same as the fror ones.
Old Mar 30, 2005 | 05:04 PM
ChickenLover's Avatar
Hey Mike can you take some more pics with it separated so I can get a better idea of the construction and how the pins connect it all? Thanks dood.
Old Mar 30, 2005 | 05:47 PM
4RunnerKid's Avatar
Old Mar 30, 2005 | 06:06 PM
KevyWevy's Avatar
im interested to see if those would work with a lift like mine. it seems that since i have BJ spacers and cranked torsion bars that the angle of the lower control arm would make it extremely hard to put back on without undoing the bottom nut.
Old Mar 30, 2005 | 06:38 PM
4Crawler's Avatar
I can make custom length disconnects for use with lifts. Just tell me the center to center length you want (ideally to restore the end of the sway bars to their stock (usually level) orientation, and the end mounting style (straight or right angle):
Straight style:
Not shown is the bolt-on right angle adapter that converts the horizontal mount to a vertical style (only needed on the 4Runners, pickups use straight end links):
http://www.4crawler.com/4x4/CheapTri...#DisconnectsV2
Old Mar 30, 2005 | 06:42 PM
green91runner's Avatar
the reason there are 2 pins is to remove the large center section, if you just 'broke' the link between the control arm and the sway bar, as you were going up the trail the 'center' piece would be hitting the swaybar, causing possible damage to your newly acquired disco's
Old Mar 30, 2005 | 07:06 PM
Praufet's Avatar
That makes sense. Mike is the right angle end a female heim?
Old Mar 30, 2005 | 07:12 PM
KevyWevy's Avatar
[QUOTE=4Crawler]I can make custom length disconnects for use with lifts. Just tell me the center to center length you want (ideally to restore the end of the sway bars to their stock (usually level) orientation, and the end mounting style (straight or right angle):
[QUOTE]
yeah, but with the BJ and torsion bar crank, if you were to connect the bottom part of the endlink (the part that connects to the lower control arm) the endlink will be perpindikular (sp?) to the control arm and since the control arm is at an angle (providing lift in the front) you would not be able to connect the top.
i don't know if that made any sense, so say that you take those quick disconnects and put them on. then disconnect them. the top half of the endlink would be vertical, but the bottom half would be at an angle, thus making it pretty much impossible reconnect the two halfs without loosening the lower part.
hopefully one of those will make sense to somebody!
Old Mar 30, 2005 | 07:19 PM
4Crawler's Avatar
If you can get an estimate of the lower end angle, an angled lower end could be designed.
Old Mar 30, 2005 | 07:42 PM
KevyWevy's Avatar
really?!?!?! hmmmmmm *runs out to his truck with a protractor*
Old Mar 30, 2005 | 10:18 PM
4RunnerKid's Avatar
yup, sure is.
i tried to put these on tonight, but i need longer bolts. it's just too hard to get them disconnected because those shorter bolts make the angle kinda crappy... they'll be on tomorrow morning though.
Old Apr 2, 2005 | 12:08 AM
4RunnerKid's Avatar
well, i got them on today. i had to buy longer bolts (3") to go through the heim and swaybar, to compensate for the distance between the two. i'll get pics ASAP. i'll tell you what though... it sure is nice having a front sway bar again.
Jun 1, 2021 01:51 PM
Jdgarrison
Oct 1, 2015 05:22 PM
Steezy96yota
Jul 6, 2015 10:00 AM
HRDC0R19
Jul 5, 2015 06:43 PM
CJ94yota
Jul 3, 2015 10:14 PM
