Running deep water and mud..?
Old Mar 7, 2005 | 10:44 AM
Tacoma750's Avatar
What do you guys do to your trucks to get them ready for deep water and mud? Im getting into some pretty serious wheelin, and i just want to make sure i have everything done, before its to late. THX
Old Mar 7, 2005 | 10:59 AM
jimbo74's Avatar
get a snorkel and raise the exhuast outlet.......
also make sure the cooling system is awesome.... trucks dont like mud much and it will reduce your cooling efficiency and will get hot quickly....
waterproof the computer and try to make sure the ign components ar ewell out of harms way, extend all the breather lines
Old Mar 7, 2005 | 11:16 AM
colsoncj's Avatar
make sure all engine compartment connections are well sealed (coat them in dielectric)
Old Mar 7, 2005 | 11:18 AM
colsoncj's Avatar
also, if you get in over your head, and think you've sucked water, shut it off. pull the truck out of the hole, remove all spark plugs, remove the air filter, pull the coil wire and crank it over till you shoot all the water out. reinstall the stuff with a dry air filter, and soon as you can check all crankcases for water and change where necessary....
Old Mar 7, 2005 | 12:47 PM
GodwinAustin's Avatar
mud and water are bad!
Old Mar 7, 2005 | 12:57 PM
96LtdYota's Avatar
you are only asking for trouble... play on rocks
Old Mar 8, 2005 | 06:21 PM
Yamaha+Toyota=Fun's Avatar
If your asking us this stuff then you probally shouldnt be going that deep. Get some experence first.
and spare CV's
Old Mar 8, 2005 | 06:23 PM
96LtdYota's Avatar
before you go romping in the mud looky here first https://www.yotatech.com/forums/f2/ok-who-53690/
may the force be with you
Old Mar 8, 2005 | 07:50 PM
EWAYota's Avatar
check out rodger browns site. i believe he has a section on water proofing tips.
djpg2000
Nov 11, 2020 04:56 AM
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
Jonny246
Jul 12, 2015 04:51 AM
cars-guy
Jul 11, 2015 07:51 PM
