what do you guys think.
Old Mar 15, 2005 | 10:25 AM
95yoda's Avatar
ok my 95 toyota truck has 31x10.5 bridgestone duller tires on it.
i have had my truck for 6 mo and,sad to say,have never really went under it to look around.
do you think my truck has any sort of lift at all or would these tires fit under a stock truck?
there seems to be plenty of room for body clearance.
its a reg cab 22re and manual trans. if that helps or is needed.
another question is....if i went with a smaller but still capable 4x4 tire what would i see in the way of gas milelage increses? thanks.
Old Mar 15, 2005 | 11:17 AM
95yoda's Avatar
anyone with any knoledge on this subject?
Old Mar 15, 2005 | 11:22 AM
ChickenLover's Avatar
31's will fit your truck without a lift. I don't see any worthwhile benefit in switching to smaller tires.
4Hummer's Avatar
My truck came STOCK with 31" Tires. You dont have anything special
Old Mar 15, 2005 | 11:55 AM
95yoda's Avatar
so you guys dont think a smaller tire would increse mileage?
what size would have came stock on my truck?
i dont mind them at all but after driving my 95 toyota 4 cyl and my 95 ford mustang gt vert v8 from calif to mn in my recent move.....and the cost to drive both all that way was nearly identical. about 168.00 in gas for both. i think that i could improve the mileage of my 4banger?
both were loaded up with loaded up pretty good with my stuff but the truck really struggled in the rockys.
i would have thought the truck would get alot better mileage then my 126,000 mile stang?
Old Mar 15, 2005 | 04:08 PM
bruzer1123's Avatar
You might want to look on the inside driver's door to see your vehicle info tag (either on the door itself or where the door closes). It should tell you the original size tires. I know mine came stock with 225 75 R 15s. I have 235s on now (MT/R) and I still get about 20 mpg. You might get better mileage, unless it was regeared (?).
Old Mar 16, 2005 | 11:19 AM
95yoda's Avatar
dont think it was re-geared because my speedo reads slower then im actualy going.
but i will check it out. thanks
polo451
13
Nov 20, 2016 07:49 PM
coleypull15
Nov 3, 2015 07:41 AM
coffey50
Jul 28, 2015 10:55 AM
jjrbus
Jul 19, 2015 02:06 PM
timmJ
Jul 7, 2015 02:01 PM
