mini spools
Old Mar 1, 2005 | 07:07 PM
swade_8's Avatar
Question mini spools
Ok so I've got a '88 toyota pickup, has the v6 with a 5 speed. My problem is I am planning on doing a motor swap to wither the 4.3 or a 350 not real sure yet. I also want to lock the rear end after I do it. I am under the assumption that it is a non c-clip rear end which means there should be a mini spool available for it. Does anyone know where I can find one so I can avoid the welded gears. also am I wrong in assuming it's a non c-clip rear end?. Thanks, Craig
Old Mar 1, 2005 | 07:39 PM
Adam F's Avatar
I've never heard of a mini spool for a Toyota. But you can get a full spool.
http://www.marlincrawler.com/3rd_pickup.html
It's not a c-clip rear end, the axles slide in and out on their own into the dropout differential. No clips holding it in.
Old Mar 1, 2005 | 07:41 PM
Robinhood150's Avatar
I remember a post on pirate where geiger said there's no use for a mini spool on a toyota. It was a couple years ago, I don't remember much else.
Old Mar 1, 2005 | 07:42 PM
Adam F's Avatar
Yea, I remember something about that too. I was headed over to pirate to do a search, but it seems they are down for the moment.
Old Mar 1, 2005 | 07:51 PM
They seem to be doing that a lot lately.
Old Mar 1, 2005 | 09:40 PM
Trailtoy1993's Avatar
While there should be a mini-spool available, there is not. But, marlin, randy's r&p, etc. all carry a full spool.
A2theK
Sep 30, 2016 12:50 PM
JookUpVandetti
Sep 17, 2015 09:25 PM
priest16
15
Aug 6, 2015 07:43 AM
Edionne13
Jul 9, 2015 01:59 PM
