does anyone make sway bar disconnects for the rear?
Old Apr 5, 2005 | 04:34 PM
byron4's Avatar
second gen. runner and i was wondrering if sway bar disconnects would give me any more travel in the rear and if they do then where can i get some at a reasonable price. thanks
Old Apr 5, 2005 | 07:12 PM
ianshoots's Avatar
I suupose you could start by just disconnecting your sway-bar (the not so quick way, with a wrench or two) and seeing if it give you more travel. If it does, then I'd compare the bolts that hold it on to the ones that hold the front bar. If they are the same I imagine you could use front discos in the back.
Keep in mind that I don't have a rear sway-bar, so I'm pretty much talking out of my a$$.
Old Apr 5, 2005 | 07:20 PM
4x4taco's Avatar
i dont have a rear swaybar either, so i might be talking out of my a$$ too...but i looked for front discos for my truck for a long time and never had any real success with those. i just take it on and off with the 2 nuts, takes less than 5 minutes. i usually drive around with it off anyways and the handling isnt too bad (except for that day i need to make a quick move on the highway....) you'd probably be fine just disconnecting the rear bar for good, at least IMHO
Old Apr 5, 2005 | 07:24 PM
green91runner's Avatar
i would recommend talking to roger brown at 4crawler.. just tell him what you need his standard rate on disco's is $80.. adding $10 for the 90 degree angle (what you need for the fronts).. im not 100% sure, but when i was looking under my truck today, I think they are straight endlinks.. just tell him the length.
although, some people have said that using rear disco's doesn't give you as much of a travel gain as the fronts do..
Old Apr 6, 2005 | 06:42 AM
Stump1883's Avatar
There is really no drastic gain in articulation from disconnecting the rear. Others my disagree, but I see very little, and I have been told the same from others who have done so. The limiting factor in the rear is your lower control arms, they stop the travel long before the sway bar does.
Old Apr 6, 2005 | 03:13 PM
byron4's Avatar
thank you. are there any other cheap ways of getting more travel from the rear??
Old Apr 6, 2005 | 06:49 PM
ianshoots's Avatar
[QUOTE=green91runner]i would recommend talking to roger brown at 4crawler.. just tell him what you need his standard rate on disco's is $80.. adding $10 for the 90 degree angle (what you need for the fronts)..*snip*[QUOTE]
4Crawler makes discos? I did not know that. Or were you thinking of Lars Dennert?
Old Apr 6, 2005 | 07:05 PM
nope 4crawler..
http://www.4crawler.com/4x4/CheapTricks/SwayBar.shtml
im just waiting for their shop to re-open to order mine..
*edit* scroll to the bottom, look for version 2.0... his price, email and specifications are all there.
Old Apr 6, 2005 | 07:16 PM
ianshoots's Avatar
Originally Posted by green91runner
nope 4crawler..
Hot dang! When did he add that stuff?
Old Apr 6, 2005 | 07:19 PM
Praufet's Avatar
yah, for some reason its hidden on his site, and not on the main page.
Old Apr 6, 2005 | 07:22 PM
rimpainter.com's Avatar
I would like to know if I can get discos for the rear too. The reason I want them is so I could run beefier ADDCO sways (on the street) and do a quick disconnect on the trails. If I could disco the front and rear, I could have some much improved perfomance on the street by running ADDCO's package.
That is my reasoning anyway.
Old Apr 6, 2005 | 07:27 PM
rockcrawler made a set for front and rear.. but for the life of me i could never find where to buy them.. but like i said above, you should have no problems with a custom set
Old Apr 6, 2005 | 07:58 PM
midiwall's Avatar
Cheap? Not really. In order to get more travel you have to give it more space to work in, which generally means to lift.
icentropy
Jul 11, 2015 07:21 AM
icentropy
Jul 9, 2015 02:12 PM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
Vargntucson
Jul 4, 2015 12:15 PM
