FJ80 Axle in a second gen?
Old Feb 26, 2005 | 08:26 PM
Praufet's Avatar
Just thinking out loud here, but would it be possible to put an fj80 axle in the rear of a second gen? I know there would be width differences. The fj80 did have a locker as an option and has disc brakes. If I went with a long travel front end I may want the wider rear. Anyone know?
Old Feb 27, 2005 | 06:27 AM
Flygtenstein's Avatar
A Tundra or T-100 would match the width better.
Do you know how wide 80's are?
Old Feb 27, 2005 | 07:30 AM
4Crawler's Avatar
I think the '80 axles are quite wide, like around 65" or so, a buddy has one on the front of his pickup. Also, the FJ rear axle has an offset diff, so you would need to center that or make drastic changes to the gas tank and driveshaft to make that work.
Old Feb 27, 2005 | 07:43 AM
They are 63.5 or so, and I am glad to now know they are offset. I had a recollection to that affect.
Old Feb 28, 2005 | 07:20 PM
Praufet's Avatar
Damnit I wanted the rear disc, e locker, wider and braunier axle.
Old Mar 1, 2005 | 02:06 PM
KevyWevy's Avatar
so would the rear brake assembly from a FJ80 fit the rear axle of a second gen? i'd be cool to get some disks on the back.
Old Mar 3, 2005 | 09:34 AM
dlbrunner's Avatar
I think FJ 80 Axles are 33mm, and 9", Definitely offset diff. Along this same line I was wondering if the modified control arms made by slee (they have a funky bushing to correct some angle) would fit in the 4runner control arms. this might correct some of the issues found when doing the cruiser coil install. I think the problem was the pinion angle.
Here is a possibility for the cruiser axle: use a early (3spd) or even a split cruiser case with the marlin adapter (for dual cases). This would give you the proper offsets for the driveline/axles. The other bonus is they are gear driven and the 3spd case can be geared down if dual cases are not needed. probably be issues with the spring perches and control arm mounting, not sure.
My thoughts for the ultimate toyota trail rig: 1st gen with FZJ80 axles front/rear using coils, Orion t-case with 4:1 low, and V6 tranny from marlin with the granny, and a normally aspirated, built supra motor (7mge). You would get the super beef drivetrain, good power, engine longevity (straight 6) and probably be a LOT lighter than a full Cruiser. Pipe dream for now I guess.
Old Mar 3, 2005 | 09:47 AM
KevyWevy's Avatar
hahahaha that would be simply amaizing!!!! but i don't know if i would rather have a first gen or second gen with that setup....
Old Mar 3, 2005 | 11:38 AM
dlbrunner's Avatar
1st gen Bro, Removable Hard Top!!! But I see your point the 2nd gen does have the best body style IMHO. Or the same setup with the 4.0 Lexus V8, oh yeah
polo451
13
Nov 20, 2016 07:49 PM
rustym
Aug 7, 2015 10:39 AM
deepmarsh
Aug 6, 2015 03:44 AM
Numberonedad6
Jul 30, 2015 07:10 PM
dfarr67
Jul 30, 2015 07:08 AM
