Clearing 35's...
Old Mar 16, 2005 | 09:25 AM
ozzfan1JC's Avatar
Clearing 35's...
84 Pick-up: With a 4 inch suspension lift, can I fit 35's, or will I need a BL also?
Old Mar 16, 2005 | 09:41 AM
SEAN_at_TLT's Avatar
That depends. Does your suspension lift actually add suspension travel or does it just lower the suspension away from the frame? If you are not adding much or any travel than you can probably squeeze 35's in there with the possibility of minor fender trimming. If you have a Marlin or similar kit that adds flex you will need to clearance the fire wall or move the axle forward and maybe modify the fenders and bedsides. If you plan to stuff 35's at full compression you will need to do as much cutting as you'd have to to fit 35's with no lift at all.
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
alexcarey
Oct 14, 2015 06:05 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
charlie_fong
Sep 27, 2015 10:06 PM
