Clinometer???????
Old Apr 2, 2005 | 07:33 AM
surelly09's Avatar
Clinometer???????
OK I bought this nifty little clinometer on ebay. Its the toyota model that gives you pitch and roll angles. And now well... I don't know how to hook it up. The writing is all Japanese. Anyone know what wires are what?? Color Choices:
White w/Black Stripe
Black
Red
Red w/White Stripe
I know that it works with out power but I would like to make the light and everything work properly.
Old Apr 2, 2005 | 08:47 AM
DudeBud's Avatar
just wire it to your dash lights then you can use your dimmer switch
Old Apr 2, 2005 | 04:29 PM
4Crawler's Avatar
Yep, just hook up the light in parallel with another dimming light:
http://www.4crawler.com/4x4/CheapTri...l#Installation
Old Apr 3, 2005 | 07:23 AM
surelly09's Avatar
i know that guys.... but that doesn't tell me what wires are what.....
Old Apr 3, 2005 | 07:28 AM
4Crawler's Avatar
Get a volt meter and poke around to find them, or find something that has a light behind it and use those. The back light for the cigarette lighter is one that is handy, or one of the climate control panel backlights. You may even have a connector for the clinometer stuffed someplace under the dash. Or if you are not worried about dimming, just wire the light to switched power.
Old Apr 3, 2005 | 07:32 AM
deathrunner's Avatar
You guys are totally missing his point.
He is saying thier are 4 wires coming from the inclinometer. He doesn't know what these wires do.
I didn't think the unit was powered other than the lighting....so is each of these wires for a different light bulb and one for ground?
But I believe he isn't trying to figure out how to hook it ot the truck, but rather understand the wiring of the unit itself.
Old Apr 3, 2005 | 07:38 AM
4Crawler's Avatar
Same thing, find the wires that connect to the light bulb, factory 4Runner wiring is 2 wires, Black and Black-White. Likely it is the Tercel with the 4WD indicator. Should take no more than a minute to figure out which two wires hook to the 4WD light and which two hook to the back light.
And if that is too complicated, I spent 10 seconds searching and found the color codes and added that to my web page:
Old Apr 3, 2005 | 11:13 AM
surelly09's Avatar
Got it thanks CRAWLER!! Appreciate the assistance.
diingodog
Jan 11, 2018 10:39 AM
jdwilson
Jan 30, 2010 10:31 AM
89silverpu
12
Aug 7, 2009 09:39 PM
mtbdavid
Aug 23, 2005 02:36 PM
Bob_98SR5
17
Apr 1, 2004 09:01 PM
