- OM617 Swap to 92 4Runner with Doomsday Diesel
- 2LT swapped in to replace 22RE (No Tachometer)
- Project 4Reigner - 1997 4Runner OM617
- 1Kzte EWD
- Updated Hilux1GDManualtTrans and WiringHarness in Fortuner
- 82 Pickup TDI Swap
- 94 4Runner 3VZE Chassis Engine Perches
- 1kz-te oil pan question
- Power Steering fluid compatibility - VW/Toyota
- 1.6 VW TD swap
- Long travel tdi alh swap. 93 pickup
- Toyota 1DZ Diesel into 89 4runner
- 1988 4runner OM617 swap.
- Prepping my 94 PU for an OM617 Swap
- Shoveling a Cummins R2.8 in my 85 4Runner
- 1kz-te test start
- 1992 Toyota pickup Extra Cab Om617 and auto to manual swap
- TDI Swap , stock gears??
- 1991 SAS Pickup AAZ VW Diesel
- Most powerful/reliable diesel engine swaps for 3.0 v6 92 toyota pickup
- caterpillar swap in a 92 4runner
- Om616
- Another OM617 Swap.
- 2LT Carnage
- 1990 OM617 3.0 Turbo Diesel swap
- Diesel engines for a 91 Toyota Pickup (3.0LV6)
- 3vze to 2lt(he)(ii)
- Kubota/Perkins
- 4bt swap a 1987 4runner
- OM617 crank bolt
- 1993 4Runner 3.0 V6 w/ r150f 5-speed to OM617
- 1kz/r151f transmission help
- Electric fans for OM616 swap
- OM617 Diesel swap into 92 extended cab 3vze
- om617 swap kits
- A few thoughts on JDM engines and vehicles.
- 2002 VW ALH tdi into 88 pickup
- 91 pickup Cummins R2.8 swap
- OM617 should I start with 4cyl & W156 Trans or 6 cyl with R series
- 22r bellhousing dimensions?
- Please help!! 1.9 alh swap into a 93 Toyota pickup
- 80s 4cyl Mercedes into a 94 4runner?
- 2LT engine questions
- V6 T100 to diesel (or 2JZ)
- cummins swap R.28 for 1990 4runner v6
- Speedometer help please
- Injection pump / vacuum line help please
- OM617.952 into a 1990 v6 4Runner
- '94 Pickup x 6.5L Chevy Diesel Emergency Swap
- om617 93 pickup swap
- Thoughts on OM602
- real CA swap info needed
- 1994 Diesel Swap
- 93 4X4 V6 to 2L-T build thread
- 2L-T Starter Question
- 2L-T Swap Fuel tank question
- 2l-te bolt up question ?
- vac hose and check valve for om617/yota
- 1KZ into 93 pickup ?
- Replacing A 22RE: 2L-TE, 3L-T, or 1KZ-TE ?
- 4bt in a 3rd gen runner?
- Any Ee20 boxer turbo diesel swaps
- Trouble with a 2LT any Diesel Techs out there?
- Cummins to offer 2.8 crate engines (sorta old news)
- buying tdi advice
- 1986 turbo 4runner project
- 2l-te ?
- Hilux 1kz to 1kd swap
- 1986 4runner om617 swap.
- 95 4runner om617 swap
- Need Consult on possible 1KZ TE to 95 4Runner Conversion
- OM617 into 1987 4Runner SR5
- 2001 Toyota 4Runner 1KZ-TE swap help!!
- OM617 Swap questions
- Swap 3L from Toyota forklift?
- 22 re to om617
- Is this swap worth it?
- Contemplating a 4BT swap, tell me your thoughts.
- Can anyone make me a PS pump bracket for OM617?
- Diesel swap in my future?... what's involved
- 91 4runner
- Need pics of Om617 motor mounts on a 4runner
- 3VZE to OM617 Swap- Power Steering Question
- Doing the opposite - transplanting a Toy into a Chevy
- 90 V6 OM617 4Runner Swap build
- OM617 Swap 91 Toyota Pickup
- Cheap easy fix for hot running 617's
- 1994 Pickup 3.0 to OM617 Swap
- om617 to toyota motor vibration
- All you OM617 swap guys know how to tune the IP, right. ? .
- Please help a student
- Anybody with a V6 to OM617 swap to a 22R trans?
- Best diesel swap in 93 pickup
- Diesel swap guys what's your mpg's averaging?
- Om617 4runner radiator fan with a/c
- Any interest in a group buy of L engines?
- OM617 Swap Best Transmission Options
- Toyota tdi
- vacuum shut off
- a/c in 85 toyota with om617
- :help: 2.5 D4D (2KD-FTV) SWAP
- Mercedes OM617 Oil Cooler & Lines
- OM617 Kit
- 2j diesel engine
- Just curious!
- Diesel Swap Advice
- need some help with more power on 0m617
- r150 bell housing pattern for making adapter plates and such
- pilot bearing pocket distance
- 3vze to 2lte swap?? Need advice!
- trying to save some money
- 83 om617 shut off help.
- Potential Om617 in 89 x-cab long box v6 pickup
- I need help ASAP
- 94 4 runner om617 mounts
- Complete manual for swapping OM617 into 4Runner
- TDSwaps Parts Wanted
- OM617 swap into 1988 4runner
- Any information greatly needed
- om617 swap issue someone help
- diesel conversion
- diesel transfomation
- 91 2wd om617 swap
- 4bt taco??
- OM617 swap noise and vibration suppression
- Dakota Digital Tach converter
- tdi into toyota dolphin
- 1st gen 4runner 3vze OM616 swap
- Om617 to toyota wiring/ vacuum
- Toyota Diesel 2.4
- Diesel swap into a 79-83 4x4 swap ideas
- Engine swap - 89 4runner
- 93 T100 conversion.
- wiring question
- 3vze to 5L or 3L conversion
- 94 4runner v6 to om617 swap tdswaps kit
- how much would you offer?
- 94 four runner sas and om617 swap
- OM617 Motor Mounts Help
- Transmission for 1KZE diesel swap?
- Hino 3.8L 4 Cylinder?
- OM617 Tachometer using SR5 Tach
- I've hit a snag
- 20% off sale at tdswaps!!!!!!
- Transplanter's OM617 FAQ
- which diesel?
- 2.2 3.4 perkins swap
- 3FE swap in place of a 22re
- Another OM617 Swap: 1998 Tacoma
- A340h & om617
- anyone swapped the inline 6 toyota diesel from the hil-lux into a taco?
- What are your Diesel swap results?
- 3b turbo diesel in a pickup????!!!!
- 93 4runner om617
- 4 cylinder diesel motor help!
- A340F help???
- OM617 - 87 4Runner 5-speed Swap ?'s
- Pickup Diesel Swap
- 2L-TE in place of 3vze
- cummins 4bt swap to 91 mercedes
- TD Swaps, Does anyone know status?
- Mercedes injector info!
- Would you remove a good running 22RE to install a OM617 ??
- Pilot bearing adapter.....
- Are you satisfied with you om617 swap
- 96 tacoma swap
- Factory Toyota tach with OM617
- OM617 swap questions
- om617 in a tacoma?
- '98 VW TDI into '88 4Runner
- dakota digital tach trouble
- Ideas and discussion for converting to a toyota diesel
- Diesel swap decisions...
- 617 Swap in Progress
- OM617 inspection
- Bobcat Diesel Conversion
- Mercedes PS pump question
- 88 4Runner 1kd-ftv swap (NEW) w/pics
- To those who want diesel in Commiefornia
- '88 4Runner 1KZ-TE swap
- om617 into 85' 4runner
- Anybody used tdswaps.com?
- Feasibility of a 1L diesel swap into my 1985 4runner
- Tractor Truck 92 4x4 w/MB OM617
- swap advice
- My OM617 inside build page
- 1985 xtra cab om617 build
- 1997 1.9L VW TDI into 1984 Extracab 4x4
- Dmarsh4X4's OM617 swap to 1988 4Runner
- 88 sr5 4runner om617 swap
- PowerstrokeJoe's om617 Turbo Diesel swap/build in 1990 P/up
- Project: 86 p/u sas/om617 diesel swap
- Help me finish this diesel swap
- Detroit deisel yota
- 1kzte in a Wrangler
- Winch's 2002 Tacoma 1KD-FTV (D-4D) swap
- 3B into 2LT runner
- Anyone looking to do a Mercedes diesel swap?
- Can I use diesel in my stock gas fuel system?
- Interest check: MB OM617 pilot bearing guide/drill guide
- 1kz half cut
- Which trans to put behind an OM617?
- 1st Gen P/U with OM617.951
- looking for cummins 3.3 help
- 24v cummins 2nd gen runner
- 2lt swap
- olds diesel in an 85
- Newer Diesel direct bolt in swap?
- toyota diesel swap questions
- 1.8 tdi?????
- 7.3 diesel into 87 4runner
- Who 's done Diesel Toyota KZ & KZ-TE Conversion
- 2L vs. 2LT
- 1987 1.6 VW TD + Toyota automatic trans?
- this swap is going to go down in HISTORY.. give me your .02 Canadian or .04 US
- 2l-te driveability?
- CA smog requirements vs diesel swap?
- diesel into toyota RV?
- good diesel swap/bio info/propane fumigation information (tech)
- Newb: looking to swap in a diesel???
- Anyone run a diesel?
- Looking to swap a diesel into a first gen 4runner
- turbo diesel conv need help
- diesel conversion for 98 4runner
- 1994 Landcruiser with Mercedes Benz turbo diesel running
- OM617 benz swaps
- Gauging interest on diesal conversions.
- Build thread - 87 4runner 22RE & A340 - VW 1.6 TD power
- Diesel for a T-100
- 1.8L diesel into 4x4 pickup
- 6.2 gm
- D4d
- How do you lower the stall in an auto?
- Where to buy a diesel to replace my 20R
- Mercedes Diesel Swap
- pics info anything on doing diesel swaps
- anyone swap a 4bt?
- 2.4 Diesel into '91 4Runner ?
- VW Diesel Build Up
- diesel info
- anyone done a diesel swap?
- cummins diesel swap?
