Please help!! 1.9 alh swap into a 93 Toyota pickup
Hello everyone!! I'm new to this forum but I need some help. I have a 93 Toyota that used to have a 3.9 v6 in it. I put a 1.9 alh in it and it has been going pretty smith up to this point . But I've run into something I can't figure out. I have the engin In and will idle but I can't get the throttle to work I don't know if anyone else has had this problem but if you have can you please let me know what you did to fix it. Thanks!!
Okay sorry for the delay. I have been hard at it. I have figured out that the motor is in limp mode. I have no throttle response and it is idling at 1200 rpm. It is out of a 2003 volkswagen jetta. It is a 1.9 diesel engine. Not sure if this helps on this forum but I purchased software to talk to the ecm and here are the results. Any help would be appreciated. I am trying to stop throwing money at this and diagnose it. Thanks guys.
Wednesday,27,September,2017,19:22:12:48505
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
Data version: 20170721 DS276.2
www.Ross-Tech.com
Readiness Status: 10000101 01110111 10000000 10000000
MIL Status: MIL ON
Comprehensive Components: Failed or Incomplete
Fuel System: Failed or Incomplete
Exhaust Gas Recirculation: Failed or Incomplete
Number of EOBD-related DTC(s): 5
Wednesday,27,September,2017,19:54:47:48505
www.Ross-Tech.com
Address 01: Engine (038 906 012 CP)
19:54:31 Group 000: Testing Dynamic Start of Injection
043 Engine speed (G28) - Specification (Idle): 41...46 (861...950 RPM) (Full Load): 138...148 (2900...3100 RPM)
055 Start of Injection - Specification (Idle): 12...75 (2 °ATDC ... 4 °BTDC) (Full Load): 137...215 (8...14 °BTDC)
017 Throttle Position - Specification (Idle): 0 (0 %) (Full Load): 255 (100 %)
002 Injected Quantity - Specification (Idle): 11...45 (2.2...9 mg/stroke) (Full Load): 199...214 (39.8...42.8 mg/stroke)
097 Manifold pressure - Specification (Idle): 83...106 (920...1140 mbar) (Full Load): 179...215 (1850...2250 mbar)
196 Atmospheric Pressure (BARO metric) - Specification (Full Load) 183...224 (910...1110 mbar)
099 Coolant Temp. (G62) - Specification: 80...35 (80...110 °C)
156 Intake Manifold Temp. (G42). - Specification: 182...50 (10...100 °C)
126 Fuel Temp. (G81) - Specification: 91...201 (20...80°C)
175 Air Mass (EGR On - 2 Min. after start-up) - Specification (Idle): 69...111 (230...370 mg/H)
Address 01: Engine Labels: 038-906-012-AGR.CLB
Control Module Part Number: 038 906 012 CP
Component and/or Version: 1,9l R4 EDC 0000AG 2839
Software Coding: 00001
Work Shop Code: WSC 06485
VCID: 609AA850D35874973BA-4B3C
4 Faults Found:
18058 - Powertrain Data Bus
P1650 - 35-00 - Missing Message from Instrument Cluster
18034 - Powertrain Data Bus
P1626 - 35-00 - Missing Message from TCU
17849 - EGR Valve (N18)
P1441 - 35-00 - Open Circuit or Short to Ground
18027 - Glow Plug Relay (J52)
P1619 - 35-00 - Open or Short to Ground
Readiness: 0 0 1 1 1
Address 01: DTCs cleared
4 Faults Found:
Readiness Status: 00000000 01110111 10000000 10000000
MIL Status: MIL OFF
Number of EOBD-related DTC(s): 0
19:58:13
903 /min Engine Speed (G28)
0.6 mg/str Injection Quantity
1.500 V Mod. Piston Disp. (G149)
67.5°C Coolant Temperature (G62)
6.7 % Accel. Pedal Pos. Sensor 1 (G79)
0 1 0 Operating condition
0 1 1 Brake Pedal Monitoring
000000 Cruise Control System (CCS)
255.0 Cruise Control System (CCS)
27.9°C Intake Air Temp. (G72)
560.0 mg/str Mass Air Flow (Actual)
Address 01: Engine Labels: 038-906-012-AGR.clb
5 Faults Found:
P1650 - 35-10 - Missing Message from Instrument Cluster - Intermittent
P1441 - 35-10 - Open Circuit or Short to Ground - Intermittent
P1619 - 35-10 - Open or Short to Ground - Intermittent
16764 - Glow Plug/Heater (Q6) Circuit
P0380 - 35-00 - Malfunction
Readiness: 1 4 0 1 0
That is what the vcds system in giving me any thoughts with this?
www.Ross-Tech.com
MIL Status: MIL ON
www.Ross-Tech.com
4 Faults Found:
4 Faults Found:
MIL Status: MIL OFF
19:58:13
5 Faults Found:
your problem for your pedal is that the signal is short in the pedal plus or the wires are cut some where ans water can cause this truble as well i know these cars by hart and love them to hahah
