OM617 should I start with 4cyl & W156 Trans or 6 cyl with R series
I have a conversion kit and complete running donor car but would like to buy another truck to do the swap with instead of the one I already have. Should I look for 4 cyl truck with weaker W156 series trans or look for 6 cyl truck with stronger R series trans ? The 6 cyl truck with R series trans and transfer case will need slid back and lengthen front drive shaft and shorten rear. This truck will be used as a daily driver and if there would be any off road use it would not be aggressive or very abusive use at all. I would prefer to start with 4 cyl /. W156 if trans will hold up OK.
I’m almost ready to do OM617 swap on my 84 Runner I’m going to used W56 tranny with stock starter but i read on others forums the toyo starter need to be gear reduction. Good luck and keep postings.
Use the 1.4kW starter from the "Cold Weather Package" option on RockAuto for the W56. The R150 can use the 1.8kW from a 2004 Tacoma 3.4L
Opt for the R150/V6 truck. The R150 is much stronger and a better candidate for the daily driver. The W56 has a weak 5th gear, which doesn't matter if you're only rock crawling it, and the gear driven transfer case makes it the clear winner for rock crawling. The R150 has a much stronger 5th gear setup, and since you won't be doing any hard-core rock crawling, the chain-driven transfer case will suit your needs just fine.
To clarify on the R150/OM617 swap, the rear driveshaft needs shortened (which is much cheaper than lengthening a shaft). The front has enough play in it that you don't have to touch it.
Hope this helps!
Hope this helps!
