Diesel Swaps Diesel engines
A340F help???
Old Nov 15, 2012 | 10:07 AM
KBar's Avatar
A340F help???
I've been searching for a while for a diesel that will fit the A340F trans with little to none fab work. Is there any out there that are not super hard to find? Been looking for a 2lte or a om617 for a while, recently a friend told me to check out a vw diesel motor or a 4bt cummins. But I think the cummins is too big for the engine compartment.
Old Nov 15, 2012 | 05:26 PM
Transplanter's Avatar
Tdswaps is working on a bolt up kit for that trans.541-981-3926
Old Nov 15, 2012 | 05:33 PM
KBar's Avatar
For what engine?
Old Nov 17, 2012 | 07:44 AM
Om617 and om602
Old Nov 17, 2012 | 10:08 PM
PowerstrokeJoe's Avatar
I think you will find that a 4bt is way too large to fit in a DD truck. The Vw engines seem to be pretty underpowered for our applications. With some time you could probably figure out an adapter plate for the tranny. The hardest part would be getting all the shift controls set up right.
Old Nov 26, 2012 | 07:30 PM
KBar's Avatar
I think I saw a mercedes 300 sd at my local junk yard gonna go 2moro and check out the engine hows the parts support for that motor? If its in good shape im gonna pull it and rebuild it
Old Nov 26, 2012 | 08:37 PM
Peach parts will have everything you will need at surprisingly low prices.
hawks7106
Diesel Swaps
May 16, 2016 05:44 PM
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
treadonmenot
3.4 Swaps
Aug 22, 2015 12:40 AM
tumor21
Nov 10, 2011 07:36 PM
newheeler
Jan 5, 2004 03:20 PM
