Diesel Swaps Diesel engines
wiring question
Old Jul 17, 2013 | 04:40 PM
draggin209's Avatar
wiring question
Hey guys while I'm waiting for my adapter kit to come from Tdswaps I want to start removing all the wires I can. I know the efi wires can be removed but after tht I'm lost as to what can be taking out. The truck is a 2wd 22re if tht helps. Maybe a diagram with which ones removed would help me out a lot on both the computer an fuse box side thnx guys
Old Jul 21, 2013 | 11:59 AM
waltt's Avatar
I just cut my harness about a foot out of the fire wall. Capped off all the wires. then i used the wires off of my alt to power the glow plug controller and shut off solnoid. as for gauges. my fuel gauge and volt meter still function as thay did b4. my factory oil and temp don't function anymore, and have been replaced with aftermarket ones in a pod on my A-pillar. if u want the stock gauges u will have to fit the Toyota senders to ur om617. Hope this helps. I can write up a color code if u need it.
Old Jul 21, 2013 | 06:54 PM
draggin209's Avatar
If you could do tht for me it'd be great. I was gonna try an keep the Toyota gauges stock if I could Brian is supposed to throw those parts in for me. So I was just gonna eliminate what I wasn't going to use an keep everything very minimal.
Old Jul 26, 2013 | 06:38 PM
waltt's Avatar
I posted my wire code on my thread. hope it gets u where u need to b.
Old Jul 27, 2013 | 11:16 AM
draggin209's Avatar
Thnx ill go check it out
Old Jul 28, 2013 | 02:09 PM
Captain Jack's Avatar
Tried to access with o luck. Can you please send to me?
Old Jul 28, 2013 | 02:24 PM
waltt's Avatar
https://www.yotatech.com/forums/f162...ps-kit-269111/
that's the link to my thread. it will b on the second page.
Old Jul 28, 2013 | 02:51 PM
Thanks Waltt, I have a 94 4Runner getting a OM617, 700r4 with a Dana 300 built with a LoMax 4:1 kit. Going with 4:88 gears. Are you near Vancouver? I am in Yakima.
Old Jul 28, 2013 | 07:33 PM
waltt's Avatar
Ya just a few miles east. ur welcome to check it out if ur ever in the area .
the1998sr5
15
Jul 14, 2020 08:35 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
rushw
Jul 18, 2015 01:46 PM
icentropy
Jul 14, 2015 10:23 AM
88yodabasket
Jul 13, 2015 01:32 PM
