7.3 diesel into 87 4runner
so ive had the 4runner for 2 years now. it has a new 22re engine with 10,000 miles ive put on it since install.
im currently working at a mechanic shop and had a 1997 ford powerstroke come in. body completely mangled from getting tboned. truck is considered totaled. but engine runs like a champ still. offered the guy 2000 for it. and got it.
my question is. how hard would it be to take the 7.3 and put it into an 87 4runner? how much chopping ect ect. would be needed. its complete from computer to tranny. and would give the 4runner more power then it could handle.
any ideas?
and if not possible. i am willing to see the engine. but i want to put a diesel into the runner. what would be the best and easiest engine that has power to put into it?
any ideas?
extension of frame wouldnt be a problem. and definately reinforce the frame. wonder how much the body would change. if i would need to build some custom fenders or something. its alot of power but would be sick. worry about torquin the frame tho
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Ok, if guys are running 35's with gears...
What kind of tire could a guy run with a 7.3 in the truck?
56's?
Ok, 56" tires on a SWB compact truck...
I'd say the 7.3 is overkill, but to each his own...
I'd run a Merc MO617...
Heck, me a few buddies are contemplating 4 cylinder 3.9ish Liter box truck Diesel engines in lifted and tired 80 series Cruisers...
7.3 in a Mini truck?
56's?
i believe you're telling yourself that it's not feasible....without you even knowing it.
it's way too big (2.4 liters....to 7.3....wow)
it's way too heavy...duh..it's a diesel.
i think you'd be okay with the torque and HP..toyota frames are fully boxed i believe.
you could part the Ford out..and use that money to buy a Cummins 4BT
still heavy..but not AS heavy..and some pretty darn decent numbers
And your truck would drive around with the ass end in the air.
The 4BT is crazy heavy, shakes like a paint mixer, weighs as much or more as the 7.3 and has a crazy narrow powerband...
Low to no powerbands make driving a real chore... I.e not fun, and you'll not want to drive it a lot...
Go with an automotive Diesel, one meant for driving.
Look at powerbands and you'll see two different kinds.
Basically those below 2,000rpm... And those above it.
Rarely you'll find one that like to go over 4k.
And you'll notice the higher they rev, the lower the torque numbers will be.
But, they'll be way more driver friendly and you can spread the gearing out b/c low gears on a 2k redline motor will not be going fast. Then if you gear it high, you won't have any low range off road.
Line up all your Diesels. Like the Toyota L, KZ, H, HD and Merc car Diesel motors. Compare those to old-school truck Diesel powerbands/ torque curves and you'll see it.
ok so not a 4bt or a 7.3 powerstroke. then what?
i know i can sell the powerstroke on craigslist for probably 4 grand plus. what would be a decent diesel motor with good power. but not to much weight that would fit into a 4runner? ive heard detroit deisel would work. but not sure on the specs. its a 6.2
yes the 4BT is heavy..i believe around 800lbs..
theres actually a lot of them being put into cruisers.
Profittscruisers.com i believe..something close to that..maybe proffitscruisers.com
you know that most of the old bread vans, UPS trucks(to this day....) run the 4bt.
i've been blown off by a UPS box van before...at a stop light...he looks at me..looks back..light turns green..and HE TAKES OFF...NO WAY i could keep up with him in my '86 toyota...and he was still accelerating past 60mph..fairly swiftly too.
and YES it did have a 4BT in it..he told me at the next light that that's what all the trucks run around these parts..i thought it was cool
but yes a smaller diesel would be better.
heck even the 1.9L VW TDI motors (from like 03-05 or something) are best...lightweight nice power..and the ECU can be flashed to produce like 165hp and over 250lb ft of torque very easily.
What size tires do you wanna run, and what do you want to set the truck up for?
There's play truck don't-give-a-...
And there's something like Expedition/DD.
Worlds apart on how you'd build them...
http://www.youtube.com/watch?v=vEgl5P-Ooew
Here's a VW that should get KILLER MPG with a more conservative lift and tire...
http://www.youtube.com/watch?v=zC8ZICmFKTw
4x4labs has a Merc kit, and I believe Acme has the VW... Not sure.
