Diesel Swaps Diesel engines
2lt swap
Old Oct 31, 2010 | 10:01 AM
fanjke's Avatar
2lt swap
Sry guys, i've not found answers on my question by using search.
I have toyota 4runner '91 with totaly broken 3vz engine. And i have 2lt engine (with wiring). What i need, to swap 2lt into my car? Are 3vz transmission and 2lt engine compatible?
Old Oct 31, 2010 | 10:14 AM
xxxtreme22r's Avatar
i believe you have to get the diesel bellhousing and swap it out. but the trans should still work.
https://www.yotatech.com/forums/f2/t...98/#post113208
Old Oct 31, 2010 | 10:31 AM
JamesD's Avatar
Correct. The reason why is the gas and diesel have different locations for the starter.
James
Old Oct 31, 2010 | 10:42 AM
and it's to my understanding that bellhousing is really hard to come by. Might be easier to find over there in Europe though, I have no idea. Keep us updated if you decide to do the swap.
Old Oct 31, 2010 | 11:03 AM
fanjke's Avatar
and what about engine Brackets? have 2lt and 3vz the same fixing points?
I have 2lt transmission, but i think he's broken =)
But with bellhousing =)
Ok, we'll make photos of the engine swap process.
PS:sry for my bad English - i'm from Russia
Old Oct 31, 2010 | 11:12 AM
JamesD's Avatar
The engine brackets I believe you can use the diesel ones but they will have to be moved back on the frame. If the truck was originally a 22R, I think it will bolt right it but yours is not.
sanctfy
All Other Toyota Swaps
Sep 15, 2015 02:52 PM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
Gevo
Jul 29, 2015 11:15 AM
GeoRoss
Jul 24, 2015 03:03 PM
