Diesel Swaps Diesel engines
caterpillar swap in a 92 4runner
Old May 4, 2020 | 08:26 PM
Jim McFarland's Avatar
I grew up with diesels and have always loved em and want something that'll last forever. I know there's the 2.8 Cummins and its made to fit but the 2.8s have a lot of problems supposedly I'm not sure if they've fixed them in the crate engine, but then I was looking at diesel swaps and saw someone put a v8 cat in a silverado and a landcruiser! I know there's no way I could possibly fit a 2000lb 10.4l beast of a diesel in a 4runner, but what about a smaller engine like the c4.4? its got about the same length and height of a 4bt but not as wide, puts out 140hp 400lb ft and they come from the factory up to 200hp. Anyway this is just a really long winded way of asking would this swap be possible and what supporting mods would be needed also sorry if this should be in a different section this is my first post.
c4.4 dimensions Length 24.8 in Width 24.6 in Height 37.7 in
Old May 4, 2020 | 09:02 PM
Co_94_PU's Avatar
So you want to double your horsepower and quadruple the torque output, and expect it to maintain the designed Toyota reliability?
Chassis swap a 4runner body on to your RAM frame?!
Old May 4, 2020 | 09:10 PM
I’m Just asking would it fit and what mods would need to be made obviously a different transmission, also caterpillar makes some of the most reliable diesels in the world routinely going well past a million miles
Old May 5, 2020 | 04:34 AM
Co_94_PU's Avatar
The answer to all swap "will it fit, what do I need to change" is always how much work are you willing to do and what are your intentions. You can already bend frames snap axels, twist drive shafts and destroy gear boxes with the factory parts depending on what you're trying to do.
Old May 5, 2020 | 08:35 AM
ok thanks for the response I’ve read multiple swaps but never heard of any of those things happening at most I was thing a body lift sas transmission and driveshaft if it’s possibly bend the frame then it’s not an option
Old May 5, 2020 | 11:06 AM
Co_94_PU's Avatar
You can have all that happen with the little 22re. Again what are your intentions.
PS sorry that's a 1stgen frame the later models have slightly different geometry.
Old May 5, 2020 | 01:00 PM
I’m looking for more efficiency a boatload of torque and reliability the cat also has as much horsepower as the 3vze and could be made to ~300 without much reliability change
Old May 5, 2020 | 08:32 PM
tng2000's Avatar
You could look for a diesel powered 'runner from overseas and bring in just the front half to do the swap, I was considering doing that when I had my 98. There are also plenty that have swapped in a 1.9 VW TDI diesel and with tuning you can get 200hp and plenty of torque, it won't be a cat engine, but at least you are not re-inventing the wheel !.
Old May 5, 2020 | 09:20 PM
Co_94_PU's Avatar
"More efficiency", so you want better fuel economy?
"boat load of torque".. faster acceleration, or more hill climbing. The first defeats the efficiency, the second means your going to be beefing up the whole drive train sooner or later it's engineered for a specific load (torque, weight, performance, etc..)
I think you need to elaborate on your vision, wether this is internal reflection or with feedback. Without this clear goal/expectation it (what to alter) is a impossible question.
Old May 5, 2020 | 11:22 PM
well it’ll be the same as far as making it fit as the 4bt which I know has been done in the 1st gens but mating it to the transmission is definitely gonna be harder if the transmission could even handle that much power
Old Jun 30, 2020 | 09:25 PM
Rowdy_'s Avatar
You’re missing the point, what are your intentions with the engine? It could involve bigger axles, frame reinforcement, stronger transmission components, all depends on what you are wanting to do with it. You need to figure that out first.
91-94yota
Diesel Swaps
Mar 25, 2019 04:55 AM
92whiteworkhog
Diesel Swaps
Apr 23, 2018 11:02 AM
Jamie Henderson
Apr 12, 2013 04:25 AM
fullwidthyotaon40s
Diesel Swaps
Jun 1, 2012 08:45 AM
Red3.slow
Jul 20, 2007 03:06 PM
