PDA
View Full Version : 93-98 T100s
Pages : 1 2 [3] 4 5
  1. broken door handles
  2. 97 5vz-fe broken rod.
  3. 96 T100 (Idling too high)(P0130, P0133)
  4. Problems with power windows.
  5. Backup light relay?
  6. 1996 Toyota t100 4x4 for sale
  7. 3vze mpg
  8. EGR Delete problem?
  9. T 100 200,000 mile (what to look for)
  10. Gas line leak
  11. Is the rear seat cruel and unusal punishment?
  12. Polyurethane bushings fer 2WD T-100...
  13. Need LSD for long travel pre runner
  14. Noober introduction
  15. Pulling/Wandering problem
  16. Toyota T100 power door locks**ALARM SPECIALISTS HELP**
  17. 4x4 not engaging in low, won't go into high
  18. Upper A Arm bushings
  19. Power Steering leak out the cap help
  20. 96 T100 (3.4) will not run ?
  21. 1994 front diff in my 1996??
  22. T100 zuk mod!
  23. Strange Intermittent Problem
  24. Help.
  25. Just got a 95 T100 4x4 auto trans yesterday.
  26. my plan for lifting 93' T100
  27. 3.4 piston slap?
  28. Rear Axle Seal Leaking: 1998 T100 4x4
  29. 4WD Problem
  30. Stock T100 rear bumper pics NEEDED
  31. CEL is on when the key is out
  32. Tundra Brake Modification on T-100 SR5 V6
  33. Re-engineering my T-100 4" rear suspension lift
  34. 96 T100 check engine light...help
  35. Complete loss of power at 2750 rpm (3.4 L)
  36. Power loss at 2700 RPM (3.4 L)
  37. oilpan gasket replacement
  38. t100 4wd problem...NOT ADD
  39. Door Latch Assembly - replacement
  40. Possible Clutch Issue
  41. Rough Idle Question
  42. BJ spacers diddnt actually lift my truck
  43. Noob with some ?s
  44. 1995 T100 3.4 5VZ FE Oil Cooler Question
  45. Clutch and 4x4 help please
  46. 3.4 pushing anitfreeze out overflow tank
  47. front end question
  48. Shift Solenoid Kits
  49. 3.4L V6 T100 Assembly help needed
  50. Advice on buying a T100???
  51. Front end still creaking
  52. 1996 T100 has a whirring, buzzing at low speed
  53. 80 series LC SAS?
  54. ECU Question
  55. Please tell me its not the head gasket!
  56. '93 T100 SR5 5 Spd Won't start fresh clutch
  57. parts source on the eastern coast of the states
  58. 96 t100 clutch disengagement problems
  59. T100 wont start after sitting 3 months
  60. Need help finding some parts!!!
  61. Cigarette lighter not working 95 T100
  62. Front offroad bumpers
  63. 97 t-100 check engine on
  64. Steering Wheel Resistance
  65. Can't find a bedliner!!!
  66. After motor swap questions
  67. early 96T100 MT evap system
  68. My first toyota pickup 97 T100 SR5
  69. 1/2 ton to 1 ton
  70. Alternator Adjustment Bolt Specs?
  71. At a loss on 96 T100 rough running
  72. Suggestions for new shocks
  73. 95t100 no start
  74. What to get?
  75. Strange Steering Vibration
  76. What nerf bar do you have ?
  77. Rear shocks on 93 T100
  78. '97 T100 trany swap from '93 T100
  79. 96 T100 no start in 1 out of 20 attempts
  80. Parking light fuse keeps blowing
  81. OME shocks for T100
  82. t100 ideas.
  83. Tweaks for Better Fuel Economy
  84. 1996 T100 3.4 liter 5 speed PO340 code persists
  85. P0304 misfire cylinder 4
  86. is my clutch going out?
  87. Vapor Pressure Sensor?
  88. 3.4L super charger swap
  89. T100 Rocker panel rust
  90. 93 T100 3vze Water Pump
  91. CV Boot Leakage
  92. Advice on Finding a Short
  93. Front end clank/rattle
  94. Auto Trannys
  95. Bent 2wd front suspension problem.
  96. Extended brake lines for the t100
  97. LED bulbs and modding
  98. Headers for 97 Auto 4WD.. Exist?
  99. Dead OBD2 Port?
  100. sway bar ? trouble
  101. Erratic Cold Idle
  102. Questions regarding Air Shocks on a DD
  103. My first Toy
  104. body mounts
  105. 95 T100 axle seal leaks
  106. T100 reverse question
  107. Thumbs down for Sway Away T-bars
  108. 95 Toyota T100 SAS Dana 44
  109. Northern Indiana Toy Newb
  110. 97 t100 SAS... Cant Find Write Up
  111. 96 T100 Speedometer and Odometer
  112. New to the forum
  113. Fuel line hook up on 94 T100
  114. t-100 has power but wont start
  115. meet my 96 T
  116. clutch replacement problems
  117. 96 2wd rear bushings
  118. Have you "Defeated the ADD System"?
  119. metal lines running underneath radiator leaking??
  120. Help engine will not pass 3000 RPM
  121. 4Runner to T100 Oil Pan Compatibility?
  122. axle wrap help
  123. T100 Headgasket Recall Info
  124. New to the T-100 game but not to the Toyota game ;)
  125. newbie to the t100 world
  126. 1996 T100 Ignition Switch
  127. Stupid T100 VIN question
  128. How many miles before an engine rebuild is a good idea?
  129. Dash dissassembly/replacing the speedometer cable ('96 SR5 4x4)
  130. cv axles
  131. wider wheels on t100
  132. R&P Replacement Bushings for 96 t100
  133. t100 4x4 problems
  134. Now to the rear end...
  135. Electrical/starting issue
  136. need help with 96 t100 1uzfe rear end
  137. exhaust pipe for AFR sensor
  138. Antilock Brake Actuator Not Working?
  139. clutchadjustment '95 Tioo 4wdr
  140. 96 T100 Super find!
  141. T100 Aftermarket Radiator
  142. 93 t100 3vze with a dead cylinder
  143. spare tire carrier only from other t100?
  144. Whats best for 93 t100 2wd?
  145. Post your pics!
  146. 1998 t100 sr5
  147. performance chip for the 3vz-e has anyone trued this thing?
  148. Need help!! cylinder 4 misfire problem
  149. AWorth's new 96 T100 SR5
  150. marlin crawler shifter bushings ->?
  151. Rpm problem
  152. transmission/clutch removal help!
  153. Tire wear question involving idler arm.
  154. Rebuild or swap 5vz fe
  155. Bad shifter?
  156. New truck couple problems.
  157. T100 newb questions
  158. grille guard
  159. What did this used to be? (hydraulic brake system)
  160. 3.4 clutch
  161. Trailmaster lift for T100
  162. carrier bearing 96 T100
  163. Dash rattle induced road rage, help!
  164. Needed!!! Bumper dimensions
  165. Custom Air Intake
  166. 4WD and Rear Drive Shaft Questions
  167. T-100 New Owner says Hi
  168. 95 T100 4wd issue.
  169. Help with oil housing gasket
  170. Clutch drops to floor
  171. T100 tow hitch
  172. High volume oil pump? 5VZ-FE
  173. 1995 T100 HP and Torque number look.
  174. Need help with body lift on '98 T100
  175. T100 hesitation rough idle when hot
  176. Sas t100 project
  177. Neutral Safety Switch Problems
  178. T100 over drive light blinking while driving
  179. Frozen Locks?
  180. What's easier/better - to replace the motor or replace the head gaskets?
  181. Factory amplifier power output?
  182. Sudden Blown Head Gasket or Cracked Head 3.4L
  183. 350 engine swap?
  184. Spark Plug Wires: Genuine OEM .vs. Aftermarket
  185. T100 rear sway bar
  186. '96 *t* cel problem
  187. VSV Issue
  188. Caliper ???
  189. How difficult to replace head gaskets on 5VZ-FE?
  190. 96 T-100 rear leafs
  191. Wheel Stud Replacement
  192. buying a 97 t100 xcab 3.4l 5spd 2wd today
  193. 1998 t-100
  194. Ticking after timing belt replacement
  195. 96 T100 4X4 not engaging
  196. T100 Rear Diff Cover Rusted Out--Help!!
  197. parts sources for used parts/bumpers etc
  198. Rear bumper options
  199. T100 Tire rub 31x10.5
  200. Gremlin under the hood (no-start)
  201. Front diff oil seal leak?
  202. lets see your custom mods
  203. Has anyone installed a 4" procomp on your t100
  204. new guy: t100 3.0 to tacoma 3.4 swap
  205. Help with checking trouble codes
  206. All pro u-bolt flip kit
  207. Starter question T100 2.7L 1998
  208. Headers for the T100
  209. Rear Axle Assembly 95 T100
  210. T-100 Suspension and Steering question.
  211. t100 fender flares
  212. Anyone know if new 11 TRD wheels will fit on 97T100
  213. Steering Box exploded
  214. 97 T100 xcab towing capacity
  215. T100 K&N air filter
  216. 3.0 a/c compressor
  217. ARB Snorkel Install??
  218. t100 2 wd conversion to 4wd
  219. Wife crashed my truck and tweaked the frame
  220. Exhaust woes already, opinions?
  221. 1996 T100 Transmission Issues
  222. Stupid question: gas tank size
  223. Cabin filter in the "t"?
  224. TRD Thermostat p/n
  225. Just bought a T100, one quick question!
  226. Help! Squirrels!
  227. Wiring diagram for '96 T100 radio w/ factory aplifier
  228. Tons of questions
  229. question about Intake silencer removal mod for the 96-97 3.4L...
  230. 96 t100 idle to high
  231. Tranny Swap - r150f TO a340f 98 t100
  232. 95 T100 weird sound when coasting / decelerating
  233. 1996 T100 Speedo not working..
  234. 5vz-fe Will not idle
  235. Throttle body bypass
  236. 5vz-fe cam help needed
  237. T-100 Recalls
  238. T100 Manual Hub conversion
  239. 35's with a 4" lift?
  240. Tires
  241. gauge cluster lights????
  242. 96 t100 keeps blowing EFI fuses
  243. Rust Recall
  244. Heater Problems
  245. T100 lazy seat belts
  246. T100 front wheel bearings replacement?
  247. T100 winch bumper like this one...
  248. Multiple Oil Leaks Finally Gone
  249. toyota t100 sas
  250. 2 inch lift for a T100
