View Full Version : 93-98 T100s
- T100s UNITE
- T 100 Seats
- New wheels & tires for the T100
- Help: '93 T100 Clutch Fork Travel
- Rock Sliders
- ifs7.5 gears shredded
- Replacement shocks
- tach problem
- 3.4 Liter Headers?
- Timing belt tensioner and idler
- Steering Rod Recall
- 97 T100 EGR Valve?
- Anti Freeze leak
- 97 t100
- T100 Add-a-leaf help?
- Looking to Replace this Part But I do Not Know what it is called (pic inside)
- T100 gas mileage drop?
- 1996 T100 Simple Mods
- 93 T-100 4wd problem
- Kicker Braces on a T100
- X-Tra Cab Space
- T100 RF susceptability
- T100 aftermarket stereo. Anyone been there?
- T100 pillar triple gauge pod
- who said the 3.0 aint tough?
- shackle broke, will chevy work?
- any ideas???
- 3RZ starts fine ,runs rough after warmed up
- 3rd member do others fit?
- Marshmallow brakes
- Changing the fuel filter
- runs like crap
- Wheel Fitment and Backspace
- 3.0 to 3.4 motor mount
- Ever weigh your truck?
- whining noise ?
- We are cruising now
- 97 T100 Shift Lock Override?
- Best spark plugs for a '97 3.4L supercharged?
- 94 t100 axle code
- t100 problems
- '93 t100 no crank
- ONKI Stainless Brush Guard installed
- number one dead
- Where are the weak spots?
- t100 interchangeable parts?
- Check out my new grille
- Removing 97 T100 auto hubs
- Front diff mounts bad?
- t100 replacement bedsides?
- Toyota manuals on order
- First road trip
- Expansion valve; how hard to change?
- 5 speed drops out of 1st
- '97 4x4 supercharged
- T-100/ 95
- 95 t-100
- 95 T100 automatic tranny overheating A/T oil temp?
- how do i replace bearings on axles with ABS ?
- Can i run 33's on t100 stock
- New exhaust question
- Problem mounting rear O2 sensor (newbie)
- 4wd Problem
- Loosening T100 4WD Parking Brake Bell Crank?
- Mild lift update
- ? Bolt size for popping rear brake drums off 94 T100 4wd
- ???'s for you guys with superchargers on 3.4L T100's..
- Fan Blade breaking? Please Help!!!!
- Odd noise in my T100 engine
- T100 auto transmission?
- Crankshaft Pully Bolt Snapped Off
- I need help with choosing shocks!!!
- T100 relay rod breakage
- Leveling out a T100
- Newbie has some ??? on lifting
- My 97 T100 Build Big and Low!
- Front differential problems?
- Crankshaft Pulley Question
- Clutch Pedal Braket Spring Question
- Antanna - replace power with regular??
- New T100 with Transmission issue
- Quick Question - 300m extended axles
- Just bought a T100
- 98 T100 4wd 3.4L 3"BL, BJ spacers, and 35 BFG AT's
- How to make a 98 SR5 4x4 t100 sound _B_A?
- T100 7mgte Engine Swap
- Looking at a 98 T100 4x4 xtra cab, Auto, 180k miles for $5k
- t100 lighting issue
- Does 370,000k Scare You?
- wanting to add a couple of performance mods to my 96 T100
- Lifting question
- 8.4 pinion yoke flange
- Water leakage
- tundra a-arms interchangeable with t100
- 96 t100 4X4: Suggestions/Advice
- How can i get the most out of my '95 t-100
- T100 offroad/performance mods
- help me find a bed for my T100
- what is the stock gear size is for a T-100
- T100 leaf springs
- Help Identify 2 extra plugs in my engine bay
- Replacing Engine Wiring Harness Tonight - Helpful Tips?
- T100 Towing question
- Installed 60" LED light bar
- Bumpers
- Anyone install LED tailgate light bar?
- Jammed Lock
- isf lift
- Torn CV(outer)grease splattering-Not Good-How much to fix$$
- Looking at getting a T100, advice?
- CV Joint Replacement
- Starter failure?
- T100 SAS help....
- T100 Eats Ball Joints
- 3.90 gears in a T100 4WD
- Totaled my 1996 Toyota T100
- converter/ cluches
- T-100 mild lift
- Some pix I think you'll appreciate
- My new '97 T100 4x4 SR5
- Nerf bars for my '97 4x4
- transmission swap
- Bought a 1996 T100 and have a few questions
- Safari snorkel for T100
- Questions about Jacobs Milage Master Ignition system
- New T100 4x4 owner needs advice
- iforce v8 swap in t100?
- T100 Noob ?
- 96 T100
- trading question?
- Cost to Replace Water Pump '96 T-100 3.4L
- Front Axle Removal?
- tocoma supercharger on t-100
- T100 Tranny
- im lookin for a suspension lift for 2wd t100
- Does Anynoe Have Pictures Of Fog Lights???
- Clutch Pedal Help
- My T-100 (w/ 4runner Inclinometer)
- clutch questions
- Fuses?
- Vibration
- 3400 Oil Pump Repacement
- Advice on T-100
- Back Up Lights?
- Spark Knock?
- Vibration
- Cup Holders?
- Camper Tops, anyone?
- Throttle Sticking
- axle shaft problems
- Will 32 x 11.50s fit on factory rims w/o rubbing?
- need a better clutch
- lockers
- T100 Problems
- T100 half shaft replacement $$$$$$$$$$$
- Protocol For 95' T100
- 95' T100 Problems
- Looking at a 98 4X4 xcab for sale
- Problems With the Intake
- The work load
- Warn Trans4mer bumper
- bucket seats
- High Idle
- 4 wheel drive gas millage?
- AMSOIL air filter for T100??
- Issues With T100's
- First test with new parts!
- Torsion Bars
- Rear lockers?
- vacuum solenoid
- Fitting 305/70-16 on stocker T100
- 98 T100 Broken Flex Plate Plague
- Touch up paint?
- Factory Backspacing???
- New T100 Wiper Issues
- New T100 Cruise Control problem
- Any VSV??
- T-100 mods
- Value for 1997 T100
- lift 4 the t100
- Oil Dipstick Tube
- Steer clear of the 3.0L engine?
- T-100 Spool?
- t100 mods
- 265/75R16 Tires on 97 T100
- Weird Noise When Backing Up
- phantom shudder
- toyota t100 4wd disk removal
- 95 3RZ-FE head gasket replacement tips?
- gas mileage
- T100 Speed Sensos
- Newbie Question about Tow Rating
- New Old School Shoes On The T !!!
- engine swap
- sas
- Anyone know the size of the center pins?
- engine swap?
- Cab/Sill Advice
- what is the width of a T-100
- Lighting problems when the brake pedal is pressed
- T100 Parts
- My T needs an ECU!
- 96 T-100 Speaker Question.
- Transmission Shifting Help! - 3.0 to 3.4 Swap Question...
- 96 T100 for sale
- Hood Flex at Highway Speeds
- T100 alloy wheels?
- Looking for front poly sway bar bushings
- diesel in a t100?
- 3.0 to 3.4 swap help....
- How to trick-out a T-100
- diagnostic code
- Check engine light on, any way to get it to show code?
- Rear Driveshaft Woes -- source?
- T100 ABS Light
- 1993 T100 automatic trans same/compatible as 95 up for 3.4 swap?
- Braking Problem
- Brake light comes on and off?
- how to separate rotor/hub on 96 4wd?
- My truck is dying...
- T100 Curb Weight?
- New member T-100 Pictures
- T100 Build-up
- Brake Problems-Please Help
- rear diff repair, need advice
- Deckplate mod
- Lifts and Tires
- Replacement rear shocks for T100 4wd- what would have SOFTEST ride quality?
- Fixing saggy butt syndrome
- Rear Axle Seals - Revisited
- question on tires
- Oil leaks common on the 3.4L?
- T100 - when coming to complete stop, should there be a movement when brake released?
- Rear Diff Issue??
- What should the be max price I pay for a 98' T100 w/70K?
- New Member *pics*
- Antenna Removal and Antenna Relay
- New Rotors/Brake Pads
- Broken T100 Idler Arm
- strait axle
- Slight misfire at idle when in park
- 96' T100 - axles - auto disconnect or manual?
- spring spacers
- Prerunner bar for 95 T-100
- Anyone interested in 93 4X4 T100?
- T100 Won't Start
- question on tires with lift
- Noise under dash when accelerating...
- Bed Rail Caps
- Share ideas to improve performance and fuel economy for the T100 3.4L engine.
