93-98 T100s All T100 trucks
Cost to Replace Water Pump '96 T-100 3.4L
Old Jun 28, 2008 | 06:42 AM
urschris's Avatar
Does anyone know the cost to replace the water pump on a '96 T-100 4x4 with the 3.4L engine? Mine seems to be leaking. Thanks very much.
Old Jun 28, 2008 | 06:57 AM
misterzee's Avatar
Probably a couple hundred bucks at least because you're taking the front of the engine off to get to it.
HOWEVER ----
Typically, when its time for your second timing belt... 120,000 miles give or take, one usually replaces the water pump while he's in there. If your mileage says time for a timing belt, just have them do both. An independent shop will typically charge $800 appx for this, and the stealership will typically charge twice that...
Am i close on this guys????
Old Jun 28, 2008 | 08:45 AM
89macrunner's Avatar
I paid just under $500 to have it done at the dealership. They changed my timing belt, water pump, all drive belts, and flushed the coolant, and gave me a loaner for the day.
Old Jun 28, 2008 | 03:00 PM
Froggy93's Avatar
Around $500-600 is about what you will pay at a dealership. and they will replace the timing belt and drive belts when they do it. Gernerall rule of thumb is T-belt, water pump, and drive belts need done around 90K. If you do it yourself, your're probably looking at about ~$350ish for parts from the dealer.
Old Jul 5, 2008 | 06:26 AM
becaron's Avatar
Maybe if you buy everything from the dealer.
I just bought the belt from the dealer which was $55, and bought a water pump and belts from car quest.
Old Jul 5, 2008 | 09:34 AM
toytech76's Avatar
I use factoy parts and will do the whole job parts and labor for less than $350. OUr shop charges $300 for just a tbelt and another $150 for the w/p I beleive. BTW...your 2nd tbelt should be done at 180K not 120K. Tbelts are every 90K by factory recommendations. Of course the stealer want you to do it every 60K.
lledwod
Aug 30, 2016 01:03 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
