93-98 T100s All T100 trucks
3.90 gears in a T100 4WD
Old Dec 8, 2008 | 11:23 AM
91diesel's Avatar
Do you guys know of anyone that has a T100 with the 3.90 (3.91-3.92) gear ratio? or of one wrecked, in a junk yard etc? I have a 91 p/u with a diesel and I think the 3.90 ratio would be perfect for hwy cruising rpm. But buying a new gear set is hard to justify with the 1-2mpg I might get as an increase. I have a 4.56 geared or 4.10 geared front end to swap if anyone is interested. Thanks!
Old Dec 8, 2008 | 06:28 PM
BamZipPow's Avatar
This is what I found on car-part.com
Axle Assy Rear
4 cyl, AT, 4.08 ratio
4 cyl, MT, 3.77 ratio
6 cyl, 4x2, w/ABS, 1/2 ton, 3.77 ratio
4 cyl, AT, 3.92 ratio
6 cyl, 4x2, w/ABS, 1/2 ton, 3.92 ratio
6 cyl, 4x2, w/o ABS; 1/2 ton; 3.77 ratio
6 cyl, 4x2, w/o ABS; 1/2 ton; 3.91 ratio
4 cyl, MT, 3.62 ratio
6 cyl, 4x2, w/ABS, 1 ton (3.92 ratio)
6 cyl, 4x2, w/o ABS; 1 ton (3.91 ratio)
6 cyl, 4x4, w/o ABS; 3.91 ratio
6 cyl, 4x4, w/o ABS; 4.10 ratio
6 cyl, 4x4, w/o ABS; 4.30 ratio
6 cyl, 4x4, w/ABS, 3.91 ratio
6 cyl, 4x4, w/ABS, 4.30 ratio
6 cyl, 4x4, w/ABS, 4.10 ratio
Old Dec 8, 2008 | 08:03 PM
91diesel's Avatar
I know 3.90 rears are easy to get, I'm looking for a cheap 3.90 ifs front. It has to be pre-tacoma for the correct diff and rotation. Thanks for looking though.
young buck
18
Aug 27, 2018 02:40 PM
mskalmus
May 28, 2017 07:51 AM
polo451
13
Nov 20, 2016 07:49 PM
Athansinis
Jul 27, 2015 08:38 AM
jgwerth
Jul 16, 2015 03:23 PM
