93-98 T100s All T100 trucks
95' T100 Problems
Old Jan 21, 2008 | 06:55 PM
aron075's Avatar
95' T100 Problems
I'm having problems finding out if my 95' T100 is OBD II certified. I've looked on the VECI sticker and it should be on there, but it's not. I have no clue where it could be. If anyone has any suggestions it would be much appreciated.
Old Jan 21, 2008 | 06:59 PM
CJM's Avatar
CJM
Diagnostics is either under the hood near the plenum or under the dash. Little plug thats says OBD on it.
Old Jan 21, 2008 | 07:51 PM
Klierslc's Avatar
It should be.....
Old Jan 21, 2008 | 07:56 PM
DeathCougar's Avatar
Under the hood is a black connector, about 1/2 size of credit card, and about 1" thick. Thats the OBD2 connector.
Old Jan 21, 2008 | 08:33 PM
aron075's Avatar
Cougar, does it say diagnostics on it. I know where that's at, but I don't know if the truck is OBD II certified because I was wanting to buy a diagnostics scanner for it. As of right now I can't tell if it is.
Old Jan 21, 2008 | 09:10 PM
yea, the black box i am talking about should say diagnostics
Old Jan 21, 2008 | 10:27 PM
BamZipPow's Avatar
Take it to Autozone and have them read the codes off of it...they should be able to tell you if it's OBD I/II...
Old Jan 24, 2008 | 09:36 AM
funnyguy44444's Avatar
The black box that says diagnostics is a toyota specific part that only dealers have the equipment to use. The plug for any regular OBD 2 reader is located on the drivers side underneath the steering wheel to the right. Its kind of right above your right leg when your driving.
Old Jan 24, 2008 | 07:15 PM
elnido's Avatar
My 3.4 L 1995 (JULY) is OBD2
Old Jan 24, 2008 | 07:19 PM
CJM's Avatar
CJM
Then why can my shops snap on scanner read it?
Old Jan 25, 2008 | 10:14 AM
Klierslc's Avatar
They probably have a toyota adapter plug. The diagnostic port on the toyotas is unique, but the OBD II port is standard (ish)
polo451
13
Nov 20, 2016 07:49 PM
Cabell
Jul 24, 2015 12:14 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
jgwerth
Jul 16, 2015 03:23 PM
taller1
Jul 16, 2015 03:00 PM
