93-98 T100s All T100 trucks
vacuum solenoid
Old Dec 22, 2007 | 12:09 PM
jnaumann's Avatar
vacuum solenoid
Where can I find salvage vacuum solenoid switches for my t-100 ADD. front axle. Mine appear to be shot. I hear new ones are really expensive!
Old Jan 3, 2008 | 12:53 PM
jnaumann's Avatar
Found a VSV for '95 T-100
Well, I found a salvage yard that says it has the vsv for my automatic 4wd. I am just afraid it is probably in the same condition mine is in. They want $50 for it. It's 150 miles from me. Sounds kind of pricey.
It's off a '95. Think I should maybe hold out and try to find a part from a later model T-100 or 4-runner or Taco?
Old Jan 3, 2008 | 01:59 PM
4Crawler's Avatar
Have you tested yours? Coil should have a small resistance (under 100 ohms) and the solenoid should "click" with power application. If that is OK, check for free air flow through when powered up. If blocked, try cleaning the air passages and see if you can open them up. I still have the original VSVs on my '85 4Runner, they last a long time.
Old Jan 7, 2008 | 10:09 AM
Klierslc's Avatar
I posted the manual pages with tests on the link below.
http://forum.ih8mud.com/95-gen-toyot...-problems.html
kawazx636
Oct 6, 2021 03:03 PM
Steven.m.paulk
Jun 7, 2020 10:45 AM
zytra
Jan 24, 2019 03:16 PM
Ditch Doc
Oct 27, 2015 03:20 PM
zanzabar0
Oct 11, 2015 02:56 AM
