93-98 T100s All T100 trucks
Anyone know the size of the center pins?
Old Jun 5, 2007 | 06:49 PM
JM's Avatar
JM
I Have a couple of aal that I got free but did not get the center pins with them. I thought I could got to Home Depot and get some allen head bolts but I do not know the correct size. Can anyone help?
Thanks
Old Jun 5, 2007 | 06:57 PM
WATRD's Avatar
It depends upon the spring.
http://www.suspensionconnection.com/...tion/to=r.html
Old Jun 5, 2007 | 07:03 PM
JM's Avatar
JM
Thanks for the link but that does not tell me the Toyota Tacoma factory center pin bolt size.
Old Jun 5, 2007 | 07:08 PM
WATRD's Avatar
Again, it depends upon the springs. Toyota uses at least two different sizes.
Old Jun 5, 2007 | 07:12 PM
JM's Avatar
JM
Thanks Rob. I did not know they use two different sizes. I guess I will have to remove one and match it up.
Old Jun 5, 2007 | 07:14 PM
WATRD's Avatar
That would be your best bet... or... post up the model and year and I bet someone can narrow it down for you
Old Jun 5, 2007 | 07:28 PM
JM's Avatar
JM
Well the model is a T-100 1996. Now I know what you are saying " Why did you post it in the Tacoma section". The reason is there is not to much on the T-100 section and I think the Tacoma and the Tundra/T-100 share some of the same rear lift parts.
I like my T-100 but there is very little on tech support and modifications.
Marc
Old Jun 7, 2007 | 05:31 AM
JM's Avatar
JM
Found out it is a 3/8 bolt. I used the 2 1/2 " x3/8 worked great.
Old Jun 12, 2007 | 11:47 AM
4Crawler's Avatar
Likely the Toyota bolt is actually 10mm, but 3/8" works fine. Also the AAL is probably drilled for the slightly smaller 3/8" bolt:
- http://www.4crawler.com/4x4/ForSale/...ml#CenterBolts
justdifferentials
Just Differentials
14
Sep 24, 2017 08:32 PM
justdifferentials
Just Differentials
Aug 30, 2015 08:42 PM
Gravel Maker
RuffStuff
Aug 6, 2015 04:27 PM
Gravel Maker
RuffStuff
Jul 27, 2015 06:53 PM
hangtown88toy
Jul 10, 2015 02:33 PM
