93-98 T100s All T100 trucks
gas mileage
Old Aug 15, 2007 | 12:10 PM
fezzyt100's Avatar
gas mileage
everywhere i look peoples t100s are gettin 18-20mpg but mine only gets 15-17 and that is driving conservativley. mine is completely stock 97 sr5 with 153,xxx miles. if someone can piont me in the right direction on how to make it better i would greatly appreciate it
Old Aug 15, 2007 | 12:47 PM
ewong's Avatar
auto or stick?
4cly or v6?
How far off are you from the EPA numbers?
http://www.fueleconomy.gov/
Old Aug 16, 2007 | 06:20 AM
fezzyt100's Avatar
3.4 v6 auto
Old Aug 16, 2007 | 07:06 AM
ewong's Avatar
EPA Adjusted "new"standard" - 14mpg city 16mpg highway.
Yer right on target
Note that the MANUAL is 15mpg city - 17mpg highway
a 96 2WD 4cly manal is 18/22 and a 2WD 4cly auto is 17/20
So there's the differnce
Ditcht he transfer casem the front axle (probably what - 500lbs) and get a manual... and violia
Or get a Honda Civi
Old Aug 16, 2007 | 09:36 AM
fezzyt100's Avatar
good to know. thanks a lot
Old Aug 16, 2007 | 09:41 AM
CJM's Avatar
CJM
Bout what I get, 16mpg city if I am lucky. I have a 96 3.4L Auto with 31's but they ride rough (tires). best I have gotten was 17-18mpg or so during october.
Old Aug 16, 2007 | 09:52 AM
ewong's Avatar
Beating the EPA numbers is doable but
-- not easy
-- not inexpensive
-- usually not feasible for a DD
Some of the things are "banned" by the EPA - as int he manufs cant used them to improve fuel economy on the Govt test - but you can use them
-- synth lube
-- lower rolling resistance tires (increased air pressure etc)
Others are do-able but often not feasible
-- TALLER gears
-- cut out weight
ALot of it has to do with the driver's right foot and is often not realistic on a road with other cars.
Long run - Id toss out a max of 20% improvement on the high side - so that means a 20mpg goes to 24mpg?
But a realistic number is a 10% improvement - and even that takes discipline - so thats 20mpg boosted to 22mpg.
In your case that means a 15mpg becomes 16.5mpg and a high (but probably unrealstic 18mpg) and note that even that 18mpg is still in the EPA "window" at the highway level...
TANSTAAFL
Old Sep 1, 2007 | 07:40 PM
mywomanstaco's Avatar
i just bought a 95 t100 4x4 ext cab 3.4 with 5speed. this thing turns around 3000 rpm at 70 mph whereas my fiances 4runner with the auto turns barely 2200 rpm at 70. i expected bad mileage with such a high cruise rpm but got 20 mpg country/town driving and 21.4 highway on a trip to indiana! im rather happy! i also drive like a grandpa and set the cruise at 65 ish on the highway. id like to know why the drastic difference in the cruising rpms between the 5 sp and auto trannies.
Old Sep 13, 2007 | 12:37 PM
BamZipPow's Avatar
Originally Posted by mywomanstaco
i just bought a 95 t100 4x4 ext cab 3.4 with 5speed. this thing turns around 3000 rpm at 70 miles per hour whereas my fiances 4runner with the auto turns barely 2200 rpm at 70. i expected bad mileage with such a high cruise rpm but got 20 mpg country/town driving and 21.4 highway on a trip to indiana! im rather happy! i also drive like a grandpa and set the cruise at 65 ish on the highway. id like to know why the drastic difference in the cruising rpms between the 5 sp and auto trannies.
Gonna guess that yer differential ratio is higher than her auto. You wouldn't happen to know what it is fer yer truck, do you?
Old Sep 13, 2007 | 12:49 PM
Bagger's Avatar
T100's - manuals come with 4.10's stock, auto's come with 4.30's stock.
Old Oct 28, 2007 | 05:32 PM
DMG's Avatar
DMG
The m/t overdrive is about .85 whereas the autos is about .70:1
Old Oct 29, 2007 | 06:16 AM
BamZipPow's Avatar
The best I ever got in my 93 2WD T100 auto was 26.4mpg highway/day/light load...and that was driving around 60 mph. I average around 20-22 on the highway now traveling around 65 mph at night. The lowest I got was around 14 mph towing my car...
Old Oct 29, 2007 | 05:35 PM
Froggy93's Avatar
I wish I could get that kind of gas mileage with my T100. best I ever got was about 18.5. that was doing about 70-73 down the highway. but, I expect that with the factory gears. 4.70 stock. crank about 3000rpms at 68ish MPH.
Old Oct 30, 2007 | 05:55 PM
RETRO's Avatar
I had a 95 xtra cab sr5 4x4 5 speed..I was getting 17 around town and 20 on the hwy from the time I bought it till I sold it..I put 130,000 on it and sold it had 194,000 on it..Several times i got 21 mpg out of it..
he's gone
7
Dec 3, 2019 07:08 AM
accuracy
Aug 30, 2015 09:47 PM
raptor510
Aug 19, 2015 02:15 PM
Tacoma1313
Aug 17, 2015 05:44 PM
nonstop
7
Aug 11, 2015 09:26 AM
