93-98 T100s All T100 trucks
Torsion Bars
Old Dec 23, 2007 | 05:19 PM
offroadie's Avatar
Torsion Bars
Has anyone done any work on their torsion bars? When I got my T, the guy that had it before me tightened those things DOWN to level the front end. It sits nice, but the ride is a little jittery. A local shop said to give 'em some slack to soften the ride, but it'd also lower the stance...
So, I go to try and back the bolts off, and they're so rusted that I'm worried that I'm going to snap 'em! I'm currently working the entire contents of "liquid wrench" can on 'em slowly (daily dosage).
Any tips/pointers/suggestions? Also, if I torque these things in half - where can I get new ones for a reasonable price? Upgrades?
ting...ting...tiiiiing...
Old Dec 23, 2007 | 05:35 PM
seafarinman's Avatar
Well I would not recommend aftermarket ones. I had the Sway-a-way ones and well after running them cranked a lot, I only found less flex, and a rougher ride than the stock ones. I recommend that you loosen them and get some of the SDORI Balljoint spacers so that you can have the lift and still a nice compliant ride.
Old Dec 23, 2007 | 05:57 PM
BLKNBLU's Avatar
I was lucky and did not break mine but have heard that it is frequently the case that they do. Somebody on here has to know a part # and if it is dealer only. (I bet yes) Maybe edit your title to "t bar adjusting nuts" or something along those lines. There have been enough "t bar" threads on this board that some folks might not even look past the title any more.
Old Dec 23, 2007 | 07:20 PM
Steveh29's Avatar
I had Sway A Way bars for a while and they were indeed terrible for wheeling. I could turn real sharp because they were so stiff, but that was the only quality they had. I since switched to Old Man Emu t bars and LOVE them. Wish I'd bought them years ago. They are thicker than stock but have a much nicer / softer ride than stock and keep my ride height with an ARB bumper.
Old Dec 23, 2007 | 07:29 PM
BLKNBLU's Avatar
I don't think he's talking about getting different t bars. Just talking about the adjusting bolts that he is concerned he might break.(which he would still have to deal with if he put in different t bars)
Old Dec 23, 2007 | 07:50 PM
offroadie's Avatar
yeah, both actually - my ride is a little firm with the smaller bumps at high speed (on road), but the adjusting bolts are iffy - any info is helpful, as you can see, I'm a newbie.
You guys rock!
Old Dec 23, 2007 | 08:15 PM
James Dean's Avatar
When I changed my bars my bolts snapped after about two turns on one and ten turns on the other. I had sprayed stuff on mine for three days before I evan tried. Here's the Toyota part #s for a '93: Bolt 90101-12159, Nut 90179-12074. They are a special designed bolt and nut, you won't be able to replace them with normal ones. They were only like $25 and it doesn't hurt to have new ones.
http://www.jamesdeancreations.com/4r...htm#Suspension
Old Dec 23, 2007 | 08:18 PM
James Dean's Avatar
By the way I have Old Man Emu torsion bars and 901HD coil springs and I love them. The ride is firm but not stiff. No lumber wagon here.
Old Dec 23, 2007 | 08:23 PM
BLKNBLU's Avatar
Originally Posted by James Dean
When I changed my bars my bolts snapped after about two turns. Here's the Toyota part #s: Bolt 90101-12159, Nut 90179-12074. They are a special designed bolt and nut, you won't be able to replace them with normal ones. They were only like $25 and it doesn't hurt to have new ones.
Nice!
Old Dec 23, 2007 | 08:30 PM
James Dean's Avatar
Here's a pic of a two piece version of the bolt. lol. Notice how the bolt has a shank and the nut has a sleeve that drops down into the adjuster arm. That's why regular blots and nut won't work.
Old Dec 23, 2007 | 08:35 PM
BLKNBLU's Avatar
Mine were a little different than that. I had 2 nuts up top. One about 1" or 1 1/2" thick, then a second regular sized nut as a lock. Still, as you say, not a typical hardware store item.
Old Dec 23, 2007 | 08:37 PM
James Dean's Avatar
That's true, I didn't show the lock nuts, but those are regular.
Old Dec 23, 2007 | 10:35 PM
wildcatkit52's Avatar
Here is a question. When people break these bolts, where you using air tools or hand tools? I have found that hand tools and the larger amount of torque applied causes more breakage than air.
I completely removed both sides on my 95 T100 yesterday after only a short period of time soaking. I used air tools and had no problems removing or reinstalling these.
If anybody here rides ATV's and owns a Yamaha or has messed with a banshee or the like, you will know how easy the factory lug nuts are to strip using hand tools compared to air tools. These adjustment bolts on torsion bars seem to have the same issues on almost all vehicles using torsion bars I have messed with...
Old Dec 24, 2007 | 10:25 AM
offroadie's Avatar
hmm, I haven't seen any locknuts on mine. Are they supposed to be there?
also, are the Old Man Emu bars propriatary? I've noticed a lot of "when used with our _____, for best performance" language on their site, is it cool to just use the bars alone?
Old Dec 24, 2007 | 11:27 AM
AxleIke's Avatar
Oh yes, you can use the bars alone. I have the OME bars, and love them. I have BJ spacers, then relaxed back to stock height (so my tbars are lowered 1.5") I have an aftermarket front bumper, and I can say the ride has never been better. (for a torsion bar truck. It still isn't great, but its as good as I've gotten).
I can actually use my entire flex range. Bump stop to bumpstop, very easily, which makes for better performance offroad.
I would recommend the OME tbars if you have a bumper and winch, and stock tbars if you have a stock bumper.
As for the bolts, good luck. I'd just go buy a new pair at the dealer ship. That way, if you break the old ones, no big deal.
There are different bolt/nut combos for various years. I ordered mine from the dealer, and they gave me the wrong ones, since they had a pair from a 1990 4runner in stock. I had to wait for the specific 87 ones to come in.
Old Dec 24, 2007 | 12:08 PM
BLKNBLU's Avatar
...X2
Old Dec 24, 2007 | 01:05 PM
James Dean's Avatar
Sometimes there are no locknuts. The sleeve on the nut is designed so as not to turn. My ome bars are set to stock height with 1.5" spacers for my lift. I just wanted a stoughter bar for added weight and stability. I have a front hitch for a wench cradle plus other gear.
Old Dec 24, 2007 | 04:51 PM
Jake97T's Avatar
the SAW bars arent so bad with a T100, i had them on mine before i did C/Os
Old Dec 24, 2007 | 07:22 PM
CC_yota's Avatar
Mine didn't have lock nuts either and when I got my new bolts from the dealership the exploded view for the torsion bars showed no lock nuts, but our 87 has them so it seems to be a year specific deal. I had no choice but to break the driver side bolt. The bolts are fairly inexpensive and the peace of mind is nice. I think it was Deathrunner who said he had heard of the adjuster bolts breaking on guy, puncturing the floor and hitting him in the arse.
Old Dec 25, 2007 | 04:38 PM
See Rock City's Avatar
Try "Areo Kroil" it is the best rust penetrater out there.
You can get it at Grainger or any industrial supply co.
Soak the bolts it that stuff for a few days and see what happens !!
Good Luck
