93-98 T100s All T100 trucks
Changing the fuel filter
Old Oct 19, 2009 | 04:54 PM
jrohland's Avatar
I've complained about rust and the trouble it causes. The latest problem was the fuel filter. There was no chance of getting the filter off the fuel lines without using the impact wrench. I ordered new lines since the old ones are badly rusted anway.
I could not get the flare nut unthreaded from the flex line that connects to the fuel rails. So I cut the hard line just behind the flare nut. I pulled the flex line up so I could work on getting the flare nut out. I used the 14mm impact socket and tried to get the flare nut out of the flex line. Well the impact socket stripped the fitting. Off to Sears to pick up Impact Grade Bolt-Out™ Damaged Bolt/Nut Remover. I'm here to say, these things work well. I used the 14mm damaged bolt remover and the impact wrench. It grabbed the stripped flare nut and backed it right out of the flex line.
With that problem solved I turned my attention to the filter. I did not want to replace the rear line at this time since that would require dropping the tank. So I cut the front line just in front of the filter and put the 19mm socket on the impact wrench. I used the 14mm flare nut wrench on the rear line flare nut. Using the 19mm impact socket I pounded on the filter until it unscrewed from the rear line flare nut.
Now I just put in the new filter and new front line. Job done.
Later (maybe in the spring) I will drop the tank and put in a higher flow fuel pump (I have the TRD supercharger) and new rear line. With the front line and filter already fixed (yes I used anti-seaze), I won't have to fight that at the same time.
By the way, the crap that came out of the old filter reminded me why I fought my way through this job.
jrohland
Old Oct 20, 2009 | 02:54 AM
jrohland's Avatar
Not a Sears commercial
I do not work for Sears. I am not recommending their tools over anyone elses. I just happen to have a Sears about 10 minutes from my house.
jrohland
Old Oct 21, 2009 | 05:54 PM
nikh713's Avatar
im having the same problem my filters clogged but i cant get the filter off on either side of the line. how much was the line you ordered for the front? i dont mind dropping my tank i just replaced it a few weeks ago.
Old Aug 23, 2012 | 05:47 PM
oldpool's Avatar
cant you just splice in a coupling on both sides of the fuel line? does anyone know the size thanks
Old Aug 23, 2012 | 05:57 PM
Stu Pidasso's Avatar
I removed my fuel line from the fuel filter and replaced it from the hardline up to the rail. I also put a regular in-line filter on instead of the OEM filter. I am not running this set up currently, but I may if I ever need to again. I did this to another truck I had and it worked great.
Old Aug 24, 2012 | 05:00 AM
oldpool's Avatar
I cant un-sieze the stock filter and I am going to splice it in. This is on a 2wd 93 T-100 so there's plenty of room. I would like to splice in steel line and put in oem spec filter, has a nice bracket and housing. The fuel line is 5/8" OD.
I Just rebuilt the driveshaft, and she is a real clean rust free truck that came off a farm. I looked at a few here and they all had serious rust issues.
This is a great forum glad I found this site!
Old Aug 24, 2012 | 05:59 PM
oldpool's Avatar
Well cant use the oem filter with the repair kit going to could use a delco filter. Instead I will cut off the ends of the tubing and flare them. Fairly easy to do and now have an OE filter with housing. Looks great. Repair kit is a dorman product, fuel filter repair kit 5/16" tubing.
smthwsn357
May 1, 2024 07:28 AM
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
Fundy Rider
Jul 16, 2015 01:35 AM
nick b
Jul 11, 2015 04:38 AM
