93-98 T100s All T100 trucks
Oil leaks common on the 3.4L?
Old Oct 29, 2006 | 05:08 PM
Tennesseestorm's Avatar
I guess I am just paranoid, but I think I am going to go with the white 96' T100 w/184K for $6300. I looked at it again tonight (at the lot) shined the headlights on it and looked under it again. I did not see any drips under it, but it looked like a spot on the road under it. It did not look wet, so I cannot say whether or not it was leaking out of the T.... it may have been out of something else It appeard to be directly under the oil pan, but there were no drips that I could see.
Could it have been leaking on up there somewhere and/or could it have leaked when first shut off (like on Friday) and then stopped after the engine cooled? When I tested drove it that day, I did not see any drips on our driveway when I brought it home, so as mentioned, I assume it is OK and I am just paranoid. Lets say it was an oil leak, what could it likely be (rear seal ?) and how difficult to repair? I would think if it was the rear seal that it would be further back. I am guessing that the spot I saw was at the back of the front tires, but in the middle of the truck.
Old Oct 30, 2006 | 06:24 AM
sworxx's Avatar
Apparently I have an issue with the axle seals in the rear. You can see the fluid leaking down and out of the back of the drum and dwon the tire. My truck has 127K on it, all hard miles.
Old Oct 30, 2006 | 08:24 AM
BlackToySteve's Avatar
It could just be a drip from the oil drain plug, if it came from that truck at all. Throw a creeper in your rig and get under that T100 with a flashlight and look for any drips or wet areas. That will tell you everything you need to know.
Old Oct 30, 2006 | 02:09 PM
t100's Avatar
i had the seal on my oil drain plug replaced.. it was leaking.. yes that is a known thing to happen with t100s, my neighbor who is my dads best friend has a t100 same year as mine and he has to replace his drain plug seal..
Old Oct 31, 2006 | 11:42 AM
NY T100's Avatar
Another spot to check is the rear part of the valve cover gasket. Stand on the passenger side of the engine bay near the firewall and look at the back of the engine/cylinder head area. Mine leaked after I had the valves adjusted (they re-used the old rubber gasket). I spent a Sunday afternoon a few weeks ago installing new valve cover gaskets with FIPG in all the right spots. (Form In Place Gasket).
Old Nov 18, 2006 | 11:44 AM
fjagogo's Avatar
My T-100 did that, too. It would cause the brake lining to swell up and lock up the rear wheel. Finally rebuilt the rear end (new axle bearings, seals etc.) and it stopped doing it.
Old Nov 18, 2006 | 12:31 PM
Elton's Avatar
i had a bad oil filter once
Eggslinger
Jun 8, 2019 03:32 PM
Ladythump
22
Nov 9, 2015 08:53 AM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
