93-98 T100s All T100 trucks
Fitting 305/70-16 on stocker T100
Old Dec 21, 2007 | 05:44 PM
jsuthey's Avatar
Hi All,I have a stock 98 T100.I would like to try out a set of 305/70-16 Pro Comp X-terrains on my stock wheels.Tires are from my FZJ80(good tread left,a little cupped)Went to 35's on that truck.Would these tires be ok for DD & mostly street use.Front clearance is pretty tight.No lift on truck just have bilstien shocks&currently running 275/70-16 BFG AT's.Need new tires soon,but these can make it through the winter.Just have a nail in one of the side walls that can not be plugged(slow leak)
Thanks,John
Old Dec 21, 2007 | 06:53 PM
CJM's Avatar
CJM
To wide unless the LC rims stickout a bit further and then its a stretch.. T100's will take 32x11.5 stock, a 305/70/16 is like 33x12.5.. almost..
Old Dec 21, 2007 | 10:33 PM
Klierslc's Avatar
I ran that size on my truck for a while. You have to crank the t bars way up, and even then, the fronts will still rub.. It is doable. No problems on the rears.
Tcsdef
Sep 7, 2015 11:17 PM
fabing455
Sep 7, 2015 08:08 AM
anniesball
Sep 5, 2015 08:45 AM
