93-98 T100s All T100 trucks
whining noise ?
Old Oct 1, 2009 | 07:59 AM
nikh713's Avatar
whining noise ?
just got my truck on the road. after replacing rear wheel bearings/seals. gas tank, and some body work. and i noticed while driving im hearing a pretty loud whining noise coming from under the truck but it's only when i'm on the gas. if i let off its all quiet. is it the rear diff? or maybe the center bearing? i grabbed the drive shaft and gave it a few yanks and it moves around pretty easily
Old Oct 2, 2009 | 01:29 AM
BamZipPow's Avatar
The drive shaft moves easily side to side? Sounds like you got some bad U-Joints...
Old Oct 2, 2009 | 04:39 AM
nikh713's Avatar
it has a light clunk when i get on and off the gas too, also vibrates at lower speeds
Old Oct 2, 2009 | 09:50 AM
BamZipPow's Avatar
Definitely U-joints!
Old Oct 8, 2009 | 07:56 AM
nikh713's Avatar
i checked the u-joints they're fine. if not in gear, the axle moves back and forth like i'm twisting the throttle on a motorcycle, it moves quite a bit until it grabs in the rear i believe. i'm thinking that my rear end is clunking when i take off or get on the gas because of this free movement.
Old Oct 8, 2009 | 04:08 PM
BamZipPow's Avatar
Sounds like the pumpkin/third member will need to git pulled and checked/rebuilt then.
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
