93-98 T100s All T100 trucks
number one dead
Old Sep 19, 2009 | 08:48 AM
stemo76's Avatar
number one dead
number 1 cylinder was reporting missfires. Checked compression and it was down to 125, others are at 170-175. Mechanic told me its most likely a burnt valve. The motor has 170k. Is it worth doing a head job on this or is the lower end going to go once the upper is all tightened up?
Is the head swap more difficult then most?
Old Sep 23, 2009 | 12:40 PM
BamZipPow's Avatar
If you have the right tools and time, you should be able to pull the air plenum and passenger side head off without too much of a hitch. Depending on how badly yer engine was abused, the bottom end should be fine.
Chicken12
Oct 14, 2015 03:54 PM
White Stripe
Oct 6, 2015 10:47 AM
Obmi
Oct 4, 2015 11:30 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
89YodaRunner
Sep 30, 2015 02:18 PM
