93-98 T100s All T100 trucks
axle shaft problems
Old Feb 22, 2008 | 07:28 PM
randall's Avatar
axle shaft problems
how do i get my drive axles out of the front diff?
Old Feb 22, 2008 | 07:35 PM
drew303's Avatar
There are snap rings on the ends of the shafts you access from the differential. Take em out should slide out.
check this out
http://personal.utulsa.edu/~nathan-b...23disassem.pdf
Old Feb 22, 2008 | 07:44 PM
toytech76's Avatar
you dont need to touch the snap rings. The shafts just need to be popped out. Sometimes they can be stubborn so use a long prybar and work around all edges of the shaft
Old Feb 22, 2008 | 07:47 PM
randall's Avatar
right on
I got one side off but the other side is really stuck. After you get them out how do they go back in?
A2theK
Jan 10, 2016 10:18 AM
jerusry
Oct 19, 2015 05:28 PM
gieselman
Oct 12, 2015 01:34 PM
deepmarsh
Aug 6, 2015 03:44 AM
andrewtexas123
Jul 14, 2015 04:29 AM
