View Full Version : 93-98 T100s
- Grille Clips
- Wanted good tested 3.4 5vz-fe
- Window regulator - how to change when motor fails?
- Bought Another Yota
- 1998 Toyota T100 Throwing Cylinder Misfire
- 93 t100 idle and hard start issue
- Scratching my head on an overheating issue
- Help!!!!!!!!
- Someone please just go look under their hood
- Blower immediately died
- Brake Nightmare
- No 4th Gear or O/D
- T100 Aluminum handle
- Broken Torsion Bar adjuster bolt meets floorboard
- Electrical Disaster! P0301 + P1300
- OBD2 port Data Link Error
- Rear brake 1 ton upgrade
- Brake Issue
- 1996 T100 3.4 L 4x4 Suspect ECU
- Brake/Cruise/Idle Issues
- 3.4L Swap/Engine Sources
- Anyone else have a bad gear on slider window?
- Fan shroud
- Where to find an exhaust front pipe
- Rear Shock Mounts
- 1997 T100 - Possible 3rd Member Bearing Noise
- AC Issues
- Hunting for Lower steering shaft for 4cyl T100
- Can you use Tacoma body parts on a 97 T100?
- ADD switch wiring on a 95-96 T100
- 3.4 vacuum routing in a 1995-96 T-100 and swap in a 1993.
- T100 front fender trim
- Rear shock hardware size?
- '93 T100 V8 swao (4.7l)
- Need transmission help
- 93 T100 4.7L UZ swap
- Very frustrated senior!!!
- Rear differential cross compatibility
- Exhaust Crossover Delete
- Headers for the T100
- Barra Swap Help
- Looking into buying a T100
- New to me 97 T100 with questions
- T100 wiring issues
- Rear axle parking brake
- 95 t100 solid axle swap.
- Stock Toyota wheels not fitting over 4WD T100 hub.
- '98 SR5 2WD - extreme axle or wheel hop and vibration
- Looking for leaf pack suggestions for lifted ‘93 T-100
- 1993 T100 SR5 4x4 advice/ideas
- 4x2 Transmission to 4x4 transmission.
- Lights Wiring Issue Dashboard light turn off if both back lights and front lights on
- Anyone else has a 19mm oil plug bolt instead of a 14mm?
- T100 Tailgate Stop Bumper Cushion Part 90541-05022?
- '95 T100 Parting out or looking for:
- 97 t100 exhaust help plz!
- 97 3.4l t-100 auto
- R150f stuck in second but stick moves
- 80 AMP Fusible Link
- Please Help-not good with this stuff-Going Crazy
- Not recording milage anymore
- Help with rusted vacuum hose and fuel smell
- Vibrates when braking to a stop but only in 2WD
- 97 SR5 2wd intermittent OD issue
- 5VZ in longbed configuration?
- 1997 toyota t-100
- 5vz swapped '93 T100 ADD not engaging
- 1995 T100 4x4 3.4
- WTB ABS censor 1998 T100 4X4
- Trying to find right size Bilstine shocks for lifted 95 T100
- Factory Tow Package include wiring for electric brake?
- 97 T100 Windshield Wiper Fuse Keeps Blowing
- 1995 T100 misfire.
- 94 T100 Cluster Swap
- T100 Blown Head Gasket advice
- 95 T100 DX No-Start (Fuel?) Puzzler
- Toyota T100 Discord Community Server
- '93 w/ low driver's side cylinder compressions
- 1998 T100, will not rev beyond 3K RPMs
- 96 T-100 circuit opening relay location (fuel pump relay)
- 96 T-100 Trouble starting
- 5vz-fe motor swap
- Is it hard to find parts for T100s?
- 95 T100 DX ENGINE 3.4L ENGINE, donor vin
- Windshield dilemma on 93’ T100
- 1993 T-100 Towing Conundrum
- 1997 T100 new driveline
- 94 t-100 miss/stutter please help!
- What to do to make mini?
- Need help
- Continuing my build soon.
- 1998 T100, turn key on, just click and dead
- 1998 T100 vacuum plugged ??
- 97 T100 SR5 4x4 build continues.
- T100 headlights
- Front exhaust pipe
- 4WD T100 Front Wheel Bearing Replacement
- Just thought I'd throw out a big hello and an update
- Stuck harmonic balancer
- Clutch firewall cracked
- Check tranny fluid on 3zre 2.7
- 1996 3.4 looking for a direct fit non plastic radiator any advice?
- UCA riding close to upper bumps after BJ spacer
- Oil level related to ease of gear shifting
- 95 t100-97 t100.
- Rebuilt Head has rattle and Possibly nasty exhaust sound
- '97 T-100 Fuel Pump Inop
- 1997 T100 4x4 not engaging when truck warms up
- Replacement wheel caps
- Holy shift what the steam
- Radio Security Code
- Moaning engine sound
- 93 Toyota T100 Won’t go into gear
- 96 automatic to manual swap
- Toyota T100 Fuel Tank Redesign
- Strange sound coming from front passenger
- Front Griile 1986 > 1993
- Brush guard question
- Center Heat/AC Vent Problem - 1998 T100
- 1995 Toyota t100 3.4 4x4
- OEM Skid Plate
- Which A340 trans do I have?
- Speedometer cable
- Wheel binding after wheel Bearing service
- T-100
- T100 clock won't work after aftermarket deck install
- 96 t100 stuck seatbelt cant get rear side panel out
- 96 t100 3rz-fe trouble starting
- Problem starting 96 t100
- New Owner - great truck, heater control issues
- Roll Call!!/Let's all introduce ourselves
- Advice PLEASE
- P0505 error
- Four runner wheels installed on T-100
- OBD2 connector location
- misfire mystery (another)
- Newly acquired 1998 T100
- Crossover removal
- Help Advice Needed for Neutral Safety Switch
- newbie here. 2019 tacoma rims on a 93 t100?
- New guy here
- 1996 T100 3.4 Auto RWD Transmission Pan
- Fuel filter
- Fuel filter
- Seat belt fix
- '97 T100 Body Parts
- Tie rod recomendations?
- Parasitic draw on dome light circuit
- Torsion Bars
- R150 transmission
- what gearing?
- T100 Where dose this wire plug in?
- searching for answers: 995 toyota t100 with 3rz manual transmission Code P0170
- 3.4l high idle and rpm surge when braking
- 95 3.4 tps adjusment
- T100 2wd to 4wd IFS conversion?
- Camper Overhang on T100
- Check engine light and OBD1 and OBD2 ports
- Did a bunch of work....now no start
- 93 T100 Fuel Pump Assembly Bracket
- Roll Call! Post some pics of them T100s
- 97 t100 hard cold start
- Who still uses this forum?
- 95 t100 trouble starting when engine is hot
- A/T shift linkage with 2” body lift
- Is the rear axle/differential housing the same for a 1996 and 1995?
- popping sound when in 2wd but not 4wd- any thoughts?
- stuck fuel filter
- third member
- door handles suck
- Dizzy failing
- 1995 T100 engine stalls as soon as I
- 97 T100 3.4 power loss
- 1995 T100 2wd Front rotor and bearing replacement
- Low power and slight shudder from start - 1995 T100
- 1993 t100 suspension upgrade options?
- 93-98 T100 wiring diagram/schematic
- 1996 Toyota t100 3.4 5 speed swap
- Code 52 on my 94 T100 DX
- Need help with identification of transmission
- T100 leaf spring cross reference?
- Engine Harness and ECM from 1997 T100
- 297,000 mile 5vz-fe t100
- 1998 Toyota 4Runner 4 cylinder and A/C expansion valve
- Rear locker on 1995 T100 1 Ton??
- 1996 Toyota t100 low voltage o2 sensor
- Help on 3.4l t100 A/c idler pulley bracket
- 600 Pound Piano in a T100?
- New to Me 1996 T100 Xcab 5 Speed 4x4 for my DD
- Running boards
- 97 T100 Roof Brace issue
- power door locks not working
- O2 harness?
- 95 Toyota T100 auto tranny problem
- Grinding on turning only in 4H
- Can I Install 3rd Gen 4runner headlights onto 97 T100??
- questions about air intake
- Toyota T100 Engine Swap
- 95 t100 3.4 No start - has fuel/spark
- 96 T100 Horse Power Loss
- T100 Rust Free SR5 XTR Cab Rockers
- Strange winter starting issue
- 95 T100 Must have electrical short somewhere, can’t find it
- wiring through the roof
- New here. 98 T100 owner SAS
- Runs Rough Injector Problem?
- Replacing Fuel Pressure Regulator in 1994 T100
- Starting issues in my T100
- 97 T100 SR5 4x4 3 of 4 gauges not working
- Anyone still take their T100 on road trips?
- New winch bumpers for t100
- Undercoating your T100
- 93 T100 swap
- 16" steelies 4runner spare on SR5 T100
- T-100 Heater Core
- 3wd t100
- 1995 intake
- Tires for my T100
- 96 T100 Antenna Question
- 1993 T100 head gasket
- T100 Horn wiring
- Interior Part Help...2 Different Model Codes
- 1993 Toyota T100 Cruise Hook-up
- 96 t100 throttle cable source?
- fuse box
- Driveshaft question
- 1995 5vzfe flooding
- 94 t100 help
- 5 vzfe oil leak, possibly high oil pressure?
- why wont the 4x4 in my 95 t100 engage
- 95 3.4 Supercharger, headers, 7th injector
- 1995 3.4 supercharger swap
- Clutch Line Replacement, 97 v6 4x4
- New owner: Grille removal
- 1993 T100 - Jerks under acceleration
- 1995 3.4 Vs. 1997/1998
- Exhaust System for 94 4x4?
- T-100 Lift Spindles
- Help with 3.4 Swap
- T100 maf
- T100 manual hub swap HELP!
- How much is my T100 lifted?
- 95 T100 3.4L Add OEM Cruise Control - What's all Needed?
- T 100 rock crawler question
- 1997 t100 4wd 5spd ext cab
- New battery
- 97 SR5 T00 - No power to front wheels in 4x4 (Bad Solenoid)
- 2JDave's 97' T100 2JZ-GTE swap.
- Can't start when warmed up?
- Smog help
